Old School Spark Plug Road Test?
karls59tr
Bronze
I've got the rebuilt carbs more or less set up and I'd like to have a look at the plugs while out on the road. If I remember correctly you take it up to a certain rpm?...shut the motor off...coast to a stop and check the plug condition? Am I on the right track here?
Deleted member 8987
Yes.
They key is to place vehicle in neutral and shut it off, coasting to a safe roadside stop to check sparking plug condition.
I never did a pre-set rpm test, just took it to normal road speed of about 35 or 40 in 4th, kept it there without wobbling the accelerator (steady), and shut it off.
Usually a couple of miles to make sure any loading was burned off.
Dale
Reading plugs has always seemed a black art to me. Quickly becoming a lost art too, I fear. Your regimen sounds appropriate. As I remember we didn't want the engine to be idling or on overun long, before we took a reading. Chocolate milk brown was supposed to be the ideal color on the insulator tip. There, you have the sum of my experience. Though I could share some stories of some miss reads that cost me dearly. Good Luck. It's as good an excuse as you need for a spirited drive.
Geo Hahn
I have heard of the need for a 'dead stick landing' to get an accurate reading but I just look at them in the garage after the car is parked without being idled for long. The toasty brown is there without all the roadside drama.
AEW
This is for regular leaded gas right??? I believe the desired brown is oxide of tetraethyl lead. Modern fuel gives mostly black soot if aything. Has anyone talked about taking along one of the cheap lazer thermometers and shooting the exhaust manifold up at the head branches?? Or just spit on your finger like an old Ferrari mechanic and listen for the sizzle :wink: Or... like an old Porsche mechanic and decide if it will do 125 it must be tuned...
poolboy
Maybe. That particular chart is from 77.
Probably some later versions on the net.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
K TR2/3/3A Old school penetrating oil? Triumph 24
6 rear semi eliptic spring plate - old school mechanic Spridgets 1
Lukens Old school ignition? Triumph 15
K Saving a clutch disc.....old school method? Triumph 11
UmmYeahOk Teach Me Your Old School Ways Triumph 13
B Brakes Squeal like an old School Bus Austin Healey 10
CraigLandrum Colortune vs Old School carb mixture adjustment Triumph 17
T Synching the carbs - old school Triumph 43
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
