Spark plug heat range
M
Member 10617
Viv says that he uses and prefers NGK BP5HS spark plugs over Champion. I see that TRF sells NGK BP6HS spark plugs.
I assume that the difference between that "BP5HS" and the "BP6HS" has to do with the spark plug heat range. Viv says he prefers a slightly hotter plug.
Does this mean that the PB5HS is hotter than the BP6HS? In other words, are the NGK plugs "colder" as the number rise?
From what I have learned, if you drive your car short distances at relatively low speeds, a hotter plug is better than a colder plug. Higher speed and longer drives justify a colder plug.
Any thoughts?
Dale
Lower number is hotter on NGK. Other way around on Champions. I don't like trying to tune with heat range. If everything else is right, the factory recommendation should work all around. I do like the newer tiny electrode plugs as they tend to be less prone to fouling. Especially since my carbs are old and out of tune. :smile:
M
Member 10617
Dale,
Thanks. That's what it looked like to me, but I couldn't be sure.
Since TRF only sells NGK BP6HS, I take it this would be considered "factory recommendation." I am assuming, however, that no harm will come to the engine if I bump it up a bit to NGK BP5HS... and perhaps it will perform better the way I drive my car (short distances, slow speed).
M
Member 10617
Hi George,
As far as I can find, the NGK BP5HS has a reach of 12.7 mm (1/2 inch) and the NGK PB5HS also has a reach of 1/2 inch. Both have a 14mm thread. This would make them equivalent, I assume, except for the 5 being a little hotter than the 6.
The 1.5 inch reach must be a typo. In fact, that chart is very hard to interpret because it doesn't include the "P" and the "S" in the designations.
VelodromeRacer Spark plug gap/heat range? Racing 8
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
J Spark Plug life Triumph 24
W Oil leak around spark plug Triumph 6
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
tahoe healey Champion spark plug testor Restoration & Tools 25
