TR2/3/3A Spark Plug Gap?
karls59tr
Bronze
Why is the TR3 plug gap .032 and the 4/4A gap .025? .....and if mods are added like using the the longer 4A intake manifold and exhaust header, does that change which gap to use or is it just a matter of experimenting?
Also...I think I read somewhere that the motor would perform better if the timing was set at 3/8" before BTDC? Is that 4 degrees BTDC or 8 degrees? OR is there a sweet spot in regard to timing for performance or are there just to many variables to say?:emmersed:
CJD
My TR2 and TR3A are/were gapped at .025. The gap is based on the power available from the coil. 3/8” is roughly 4degrees. But final timing should be determined by road testing.
TomMull
The TR2/3 manual does say .032. I wonder if there was a service bulletin at some point. I've always used .025 also but I don't remember where I got the number. Perhaps from the plug manufacturer's guide.
Tom
TR3driver
Great Pumpkin - R.I.P
Yes, there was a service bulletin, fairly early. I've posted it before (but maybe not on this forum), I'll see if I can find a copy.
.025" is in the owner's manuals.
Here it is, Feb 1956
PS, 3/8 translates to roughly 8 BTDC. Whether you can run that much without knock depends on a great many variables, even things like altitude and climate. Whether more is better is another question with no clear answer; I've seen tests on some engines that show better power without running on the edge of knock.
There's also the chance that you might not hear the knock under some circumstances; like high speed cruise. I never heard this one knock:
So it seems to me that backing off a bit is probably a good idea, overall. Assuming you want the engine to last, anyway; racing would be a different matter.
STeve 1958
My book said 4 degree BTDC so I started there. Then I advanced it 2 more degrees and it ran better, so I advanced it 2 more degrees and it runs great.
No noticeable knock. I might try 2 more degrees some day.
B TR6 Spark plug gap Triumph 5
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
H Spark Plug Gap Austin Healey 3
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
