Dist cap and plug wires
JohnnyO
Ok, so I want to replace my plug wires and dist. cap. I wanted to get the Cobalt Wire set sold through Moss, it says "early sprigets must use top entry cap" my cap now is the side entry type... my question is, are these two types of caps interchangeable? Can I just replace my side entry cap with the top entry cap and that's that????
Billm
Yep-
A side entry cap is better for a RHD car to keep the wires from fouling the steering column but on a LHD car either cap can be used. They both take 8mm wires.
Not sure why Moss said that, doesn't make sense to me.
BillM
aeronca65t
With the Cobalt wires, I'm pretty sure the set already has the metal connectors at the distributor end pre-attached (for the push-in style cap).
The side-entry cap just accepts plain wire (as I'm sure you know).
I guess you could cut off the connectors and push the Cobalt wire into the side-entry cap (but I'm not sure how well resistor wire works in that setup).
I prefer the side-entry caps, but I run always solid-core (non-resistor) wire.
Pythias
As long as you're changing to top entry for your cap, go to Advanced Distributors on the web and get a cap that has BRASS instead of steel or aluminum for the contact points. May as well pick up one of his "RED" rotors at the same time. You'll be glad you did.
NFI
JohnnyO
JohnnyO
Ahhh too late Bill, I already ordered from Moss, but I think I might just go ahead and get one of those caps with the brass contacts from Advanced Distributors, guess I'll just have a spare cap now.....
JeffS
Here's the reason for the disclaimer:
If you use the carbon core style plug wires with a side entry cap, you will puncture the carbon core with the cap's retaining screw. If you so much as scuff the carbon core, it will begin breaking down from arcing and burn up in short time. By pushing a screw into the wire, you're shortening the life of any carbon core plug wire dramatically.
Now here's the twist: Solid core plug wires as normally used in a side entry distirbutor cap throw off large amounts of RFI noise. We all know th enoise - it gives you the great whine on the AM radio dial. It also affects electric tachometeers and more inportantly, it can shield a Pertronix unit from reading its own magnetic signal. Yes, it WILL cause misfires when you use a side entry cap and solid wires with a Pertronix, and occasionally a Crane or Lumenition ignition kit (but far less so since they're optically triggered). I'v eseen TR4s that won't run above idle speed because of solid core wires used in conjunction with a Pertronix.
My recommendation for any car that's a driver: Use the later top entry cap (Lucas DDB-106) with carbon core plug wires no matter if you use points or electronic ignition. Keep the NOS parts for the car shows. Perfomance and reliability will be its best.
Yes, I sell great brass terminal caps and I make the red rotors that just never fail, but this is just as important. Update your plug wires and cap if you have the old side entry style. Just make the change the next time you need a tune-up.
Pythias
Thanx Jeff... hey your parts came in time for me to go but now I can't.. see my other thread on that.... I use the Bosch wires with right angles out of the cap. I can't think of the model number now, but i've been really happy with them.
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
NutmegCT Dist cap Triumph 19
G need help with dist cap conversion!!! Spridgets 22
G new dist cap doesnt work... please help!!!! MG 10
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
2 TR2/3/3A comment on dist. wire [Ebay] Triumph 4
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
rjc157 Pertronix dist Austin Healey 2
B Petronix Flamethrower Dist. Austin Healey 20
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
hondo402000 how to Check total Advance on Dist Triumph 9
A Mallory Dual Point Dist MG 6
R 1500 midget & 25d4 dist change suggestions Spridgets 6
A dual vac dist Triumph 6
64rocksprite Int trim and dist parts I cannot find-ideas? Spridgets 8
NutmegCT TR2/3/3A timing DM2P4 dist, TR3A - vacuum? Triumph 37
B Pertronix and Dist Rebuild - Car not starting Austin Healey 63
DNK Dist. Roll Pin Triumph 8
tahoe healey Dist. A/R adjustment Austin Healey 9
D wire from coil to dist Spridgets 1
B Wedge TR8 Dist Triumph 0
DNK Elec. Dist. Triumph 9
G TR6 TR6 Mallory Dist Triumph 10
L Gas Cap Recommendation Austin Healey 1
mctriumph TR2/3/3A Hub cap emblems Triumph 2
L T-Series Gear box servicing cap. MG 5
C MGB New plug wires and distributor cap MG 10
F Wanted Dipping switch cap Triumph Classifieds 1
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
Overdrive45 Trim Under Convertible Cap Austin Healey 11
E TR6 Strange Steering Rack Cap Triumph 3
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
P MGB Mgb gas tank cap MG 7
A TR6 TR6 Distributor cap issue Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
M TR6 Center cap for wheels Triumph 2
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
S TR2/3/3A TR3 gas filler cap Triumph 1
Ripper01 For Sale TR-6 Valve Cover/ Cap Triumph Classifieds 0
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
Jayplum TR2/3/3A Grease cap Triumph 25
