how to Check total Advance on Dist
hondo402000
How do you check total advance on a TR6 Dist with out reving the car up to 4000 rpm in the drive way,, Is it possible?
Hondo
TR3driver
Great Pumpkin - R.I.P
"Total" is taken as initial plus centrifugal, and on a Lucas dizzy the max centrifugal is set by a positive stop. So one way is to measure initial advance and then add the max centrifugal (which is usually marked on the stop).
But if your stop has been modified or you just don't trust it, then you'll have to spin the dizzy up. If not on the engine, then on a distributor machine. Old machines sometimes sell for cheap:
https://www.ebay.com/itm/GAS-STATION-VTG-...=item1e6768f262
Another approach that might be amusing (if your talents lie in that direction) is to install a crank sensor and build a circuit to measure and display the advance in the cockpit. But of course if you are going that far, might as well have it control the timing as well (making it adjustable from the cockpit).
DNK
Is 4000 where your total advance peaks?
Actually that isn't that much of a spin up. And it don't have to be there very long
hondo402000
hondo402000
Jeff at advance recurved my dist, and I talked to him on the phone, he said he had my file but on paper not on a computer, so he couldnt go back and tell me the total advance he set, but he did say if I increased the CR that it might need to be recurved again. but the good news is I centered the thumb wheel, set the timing at 14 BTDC, changed the choke tubes, jets in my webers back to the best setting I had and now its almost perfect, AF is in the 12.5 at idle to 13.5 range from Idle to WOT. the Miss at 3000 is gone!. I think I had the thumb wheel adjustment all the way to one side and the timing could not get to full advance. So now I am going to put some miles on it, watch the AF meter for a while and just do some tweeking.
Hondo
Brosky
Glad to see that 90% of all carb problems are electrical, once again........
poolboy
Sounds like you've gotten past the frustratin' part, Hondo and now into the fun part of the process.
Basically with the mods on your engine you have a 'one of a kind' and you won't find the answer in any book or manual as to what's your engine's sweet spot, but rather (in the absence of a "rollin road") by the ever so much fun test drive after test drive.
After nearly one year and 7000 miles on my moded engine.I find myself pretty darn close. but not so close that I want to stop tweaking.
Heck, even if I did, Winter will be here soon and I might have to make a few adjustments to be in harmony with the cold air that my carbs will soon be digesting,
hondo402000
hondo402000
they have cold air in Mississippi,,,, and do you mean from 100 degrees to 75
lol. well charlotte we can get down to the teens in the winter but then I dont drive when its that cold, now in the 30's yes
I only have 375 miles on mine and going to check cylinder pressures and send them to Jeff and see what he says
Hondo
poolboy
I saw where you mentioned the cylinder pressure. I'm guessing that would be doing a compression test, right ?
I don't get the relationship to the advance curve though.
I did 3 compression test so far on my engine
The first was at 500 miles which averaged 152
The next was at 1500 miles which averaged 166
The last was at 6700 miles which averaged 176
And, cold ? Hondo when you spend 3 months sweating at 100, 70's do actually feel cold.
hondo402000
hondo402000
yes compression test, I dont get the relationship either but Jeff at advance said if the pressures are higher than when I sent the distributor out a few years ago it would need to be recurved,
Hondo
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
AngliaGT In Check,VA Today Spotted 2
Rob Glasgow Check Strap Assembly Austin Healey 5
F TR2/3/3A Check strap alignment Triumph 11
T General Tech Once again, check the easy stuff Triumph 2
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S Price check on TR3A valve cover Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
V TR2/3/3A Vertical link check Triumph 2
R TR4/4A Door check straps Triumph 7
68_sprite Check the August Oprah Magazine Austin Healey 5
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
HighAltitudeTR3 TR2/3/3A Door Check Assembly Triumph 19
S Door Check Strap Austin Healey 5
AngliaGT Why You Should Double - Check Your Parts When You Receive them. Spridgets 2
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
C Rough Idle - What to check? Austin Healey 12
KVH TR4/4A Door Check Straps Triumph 11
S Overdrive Wiring Check Austin Healey 12
Michael Oritt Door check installation Austin Healey 7
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
warwick-steve Brake drum check and lubrication Austin Healey 9
Rut Sanity check! Spridgets 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
Mickey Richaud General Tech Always Check the Fundamentals MG 10
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
D TR2/3/3A Door check bracket? Triumph 7
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
Martinld123 Compression check 1956 BN2 Austin Healey 7
M BN1 door check replacement Austin Healey 9
R Last minute check before engine install Austin Healey 26
Boink Check out some Sprite shots at the Portland ABFM... Spridgets 1
Rut TR4/4A Get out your check books! Triumph 10
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
S How to check Dwell on a MK I 3000? Austin Healey 27
K TR2/3/3A Re: TR3 Bump stops and check straps. Triumph 18
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
jlaird Check Spam folder Spridgets 3
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
HealeyDave Door Check Friction Adjustment Austin Healey 12
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
drooartz General Tech Check those brake hoses! MG 11
sundown TR6 Door check strap Triumph 3
