nathandarby67
I am thinking of getting some of the bumblebee plug wires for my 73 midget, and have a few questions. Where is a good source for the plug boots and the metal clamps inside the rubber boots that attach to the plug ends? What about connectors to the coil? I have never used raw ignition wire to make up a set before, do you just strip back some of the insulation and push on the plug boots? With my old set, if you pull off the rubber boot there is a metal clip clamped onto the end of the wire. Where does one get these for the bumblebee wire?
