wkilleffer
A couple of months ago, I installed a Classic Gold fuel tank from Moss on my 1974 MGB. The old tank appeared to be original, showed alot of rust, and seemed to be allowing quite a bit of fuel vapors into the boot. While I was at it, I replaced all the rubber lines for fuel and evaporation, and replaced the fuel filter. I no longer smell fuel in the boot and the car seems to run better, at least when it's running...
Trouble is, I've since had a couple of instances where I've had to be towed home because insufficient fuel was making its way to the carbs. The pump's a points SU that's a little over a year old, and its connections are solid.
I'm of the belief that the fuel I poured into the new tank might have had some contaminants that weren't visible, and that they've settled near the tank's pickup tube and may have clogged the "sock" on the tube's end. Part of what may support this notion is that the time before the last time I had to be towed, I used a bicycle pump to blow backwards through the fuel line. I could hear it bubbling in the tank. After doing this, my SU pump would fill a 1-pint container in about 45 seconds. It pumped good and strong, and I thought I was home-free. But the same thing happened again. The fuel pump gets a kind of squelchy sound, and I soon find myself bogging down and at the side of the road. Removing the gas cap makes no difference.
So, I decided to drain the tank and get the bad gas out. There's a plug in the tank's bottom where a 10mm hex key fits snugly. I thought this would be a piece of cake, but it's been anything but. I've tried vice grips to no avail, and even violated a cardinal rule of tool treatment by sliding a length of pipe onto the key. All that served to do was twist the key a bit.
Has anyone else had this kind of trouble? I knew it might be tight because we don't want leakage, but I really thought it would come loose with some gentle persuasion.
Any assistance would be appreciated.
Thank you,
-William
Thank you,
-William
