TR2/3/3A Whitworth fill plug for lever shocks
jfarris
Greetings,
What is the best solution for removing and replacing the filler plug on the lever shocks on a TR3?
Maybe 6-sided 9/16 socket or has someone found a closer fit that won't eventually destroy the plug.
Thanks,
Geo Hahn
I'll confess... I never realized it was Whitworth. I suppose I used whatever looked right & fit, anyway never had a problem. I don't wail on it to tighten, just snug it up.
TR3driver
Great Pumpkin - R.I.P
What you need is a 1/4" BSW (Whitworth) socket. Your corner hardware store won't have it, but they can be found.
Here's a modest set on Amazon for under $30:
https://www.amazon.com/8pc-Drive-Whitworth-Socket-Rail/dp/B00GYH1HM8
PS, if that size seems silly, it's because Whitworth sockets are sized by the diameter of the bolt, rather than the head. 1/4 BSW is also 5/16 BSF because BSF bolts have a smaller head (relative to thread size) than BSW.
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
D Whitworth on 59 Sprite. Spridgets 11
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
JPSmit Whitworth Question Restoration & Tools 23
MikeAH100M Whitworth Source Austin Healey 8
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
LarryK Whitworth tools Restoration & Tools 5
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
M Addendum to searchin for Whitworth screws Jaguar 2
M Source needed for Whitworth-BSF screws,etc. Restoration & Tools 2
C Need info on Whitworth hardware Restoration & Tools 3
timbn2 whitworth / king dick tools... where to get.? Austin Healey 4
G I need a quick tutorial on Whitworth wrenches MG 6
B Quality of various Whitworth spanners Restoration & Tools 9
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
KVH TR4/4A TR4/4A Gas Line Whitworth Questions Triumph 0
Britishtools More in depth Whitworth Thread Information Restoration & Tools 3
Britishtools Mr Joseph Whitworth: Inventor and Engineer Restoration & Tools 7
B Whitworth - where?!? Austin Healey 7
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
C TR4/4A Best way to remove transmission fill port? Triumph 8
MY66AH Coolant Leak From Fill Neck Spridgets 3
bthompson Plastic fill plugs?! Spridgets 1
D gear box fill plug Triumph 13
nevets How much brake fluid to fill the system? Austin Healey 3
W TR6 Gearbox fill-TR6 Triumph 5
T TR2/3/3A TR3 tranny, dipstick and fill Triumph 3
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
Aggudabbu Fill in my blanks Spridgets 5
HealeyRick Rear Axle Fluid Fill Austin Healey 5
J threads on the fill plug for the steering box? Austin Healey 1
drooartz MGB Wrench for MGB diff fill plug MG 5
I How do I fill Bugeye steering rack? Spridgets 8
racer_x Wedge TR8 fill neck on gas tank Triumph 13
sparkydave Transmission fill plug access Spridgets 5
T TR6 Scary TR6 sill pictures - anyone need yard fill? Triumph 10
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
Nunyas Sealing a vented oil fill cap MG 6
T How do you Fill your transmission Triumph 10
vping Where to fill Gearbox? MG 4
nevets location of trans oil fill port? Austin Healey 18
hawkwind Tranny[gearbox] Fill Spridgets 7
NutmegCT fill 'er up? MG 6
J Gearbox Oil Fill? MG 16
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
