Setting the Distributor Drive Gear....
Dadandson
without the distributor. I am buttoning up my new 1275 motor while I still have a different 1275 in the car and running. I don't want to pull the dizzy so I can continue to drive the car and I don't have a spare. What would be the best way to set the dizzy drive gear from the cam so I can button this thing up? I won't be driving the car for a few months, shoulder surgery, and I am going to pull the dizzy and send it for rebuild while I recover.
jlaird
The factory manual says specificly how to set the drive gear. Easy stuff.
ChrisS
Set the engine so the #1 cylinder is at TDC before the power stroke. Thread a 3" to 4" long 5/16-24 bolt into the drive gear. Note the offset of the slot in the drive gear (it isn't on center) and keep the large offset on top. Inset the drive gear so that the slot is at about a 45' angle keeping in mind that the gear rotates as you insert it. Take a look at the picture on page 2 of the attachment.
  • 17340.pdf
Dadandson
Dadandson
Perfect. Thanks
spritenut
And every time I do this, it's 180 out.
Just keep that in mind, if you have a 50/50 chance, you will get it wrong 99% of the time :wink:
Of course, I can never tell which offset is which, it sure looks dead center to me.
jlaird
It is not dead center. My solution is put it in correctly then reinstall 180 degrees from what I have. Works every time. Durn thing.
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGA Setting a 123 distributor MG 0
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
J Distributor Advance Setting Spridgets 1
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
bugedd Setting Timing Spridgets 6
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
R Question on establishing a baseline timing setting Triumph 3
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
C Setting bonnet height at front? Austin Healey 8
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
rlich8 TR4/4A A baseline setting on TR4A carbs? Triumph 2
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
G Setting mixture on HS4 carbs MG 30
