Starter motor replacement - Mini Cooper S
HealeyPilot
Member
Hi,
I need to replace my starter (only seems to grab 1 in 4 tries).
My manual says "...remove cable and 3 retaining bolts and remove".
I think there are a few more steps involved. It looks like I need to remove the grill and fold down the oil cooler to get access. Is this right?
Any process help would be appreciated.
Thanks!
-Rob
Kensai
Not sure of the procedure for removing the starter on a Cooper S as my Elf seems to have a few less components in the way than your Mini.
I would suggest going through and lubing the shaft and the inside of the movable gear of the starter you have before replacing it. The starter on my Elf used to have the same problem, where the gear was not engaging the flywheel every time, and a quick lube of the movable starter components fixed it right up. Might be worth a try before handing over the money for a new starter. May be instructions in your manual but if not it's a pretty straightforward job if you're good with a wrench.
dklawson
As a point here, once you get it out, you can clean the commutator, blow out the dust, lube the bearings... but you are not supposed to lube a Bendix unit. The oil/grease applied tends to attract dirt that gums up the forward motion of the Bendix when you engage the starter. There are two camps on lubing a Bendix: 1) leave it dry, 2) apply powdered graphite or moly powder. I'm in camp #2.
Regarding the removal process, my -S is early and originally had the vertical oil cooler and now has none. The process will be much easier without the grill. However, I remember the starter having two bolts, not three.
Before pulling the starter, when you say it isn't working, what IS it doing? Do you hear the solenoid pull in? Is the starter motor spinning but not engaging the ring gear?
W General Tech 2500S starter motor and fuse box questions Triumph 3
edkap2002 TR6 starter motor advice Triumph 12
S TR2/3/3A starter motor Triumph 9
Keith_M starter motor pinion gear -- 9 or 10 teeth? Spridgets 4
S T-Series starter motor MG 2
A Starter Motor Issues Spridgets 18
A Square Body Sprite Starter Motor Issues Austin Healey 2
M tips please on removing starter motor on 100-6 Austin Healey 6
2billydavies TR2/3/3A help! again! please! starter motor Triumph 4
busybrit MGB Slight starter motor noise MG 5
B A sticky starter motor Austin Healey 1
AH67 Spinning starter motor BN7 Austin Healey 13
zeinfeld Spinning starter motor Triumph 15
H BJ7 Starter Motor, Lucas 25550 Austin Healey 1
6 Starter motor woes Spridgets 20
B Starter motor woes Austin Healey 32
H Gear reduction starter motor Austin Healey 9
D Lucas starter motor field assembly Jaguar 3
Jim_Gruber Bottom Starter Motor Bolt - How do I get it loose? Spridgets 7
G TR2/3/3A TR3A, Starter motor Triumph 5
glemon TR5/TR250 TR250 Starter Motor Placement Triumph 4
bigjones Starter motor - internal inspection Spridgets 8
TR6oldtimer TR6 TR6 Starter motor chatter Triumph 7
W starter motor binds Austin Healey 12
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
hondo402000 Starter problem and motor wont shut down Triumph 22
TR674 Starter motor Triumph 13
T Starter Motor Triumph 4
T Starter Motor Troubles Triumph 8
T Starter Motor Freeze? Triumph 2
D TR6 Wiring problem - re headlights/starter motor 74TR6 Triumph 6
S TR6 TR6 Starter motor question? Triumph 3
Obtong Alternator or Starter Motor? MG 28
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
algot1901 1950 Prefect starter Other British Cars 1
