rear main
markberry
Bob,
When I had my 948 rebuilt in Sacramento five years ago, I asked the mechanic/owner about these retro oil seals and didn't get a good recommendation from him. He had seen several types over the years and didn't think any of them were worth the money (for the amount of oil they kept from blowing by). He suggested I call Paul Asgeirsson at Morriservice in Portland (503-978-3998) and talk to him about his "fix" for the problem, which I did, and am pleasantly pleased to this day with the result. Essentially Paul's process involves rebuilding the worn area of the crescent shaped cap bolted to the block on top of the rear main bearing cap and of the cap itself, in order to close up the gap that has formed with the last fifty years of wear and tear. Anyway, the repair took a full day (two-three hours of actual work) due to the drying/hardening of the material used, but the result was (and still is) a leak free engine for around twenty bucks!
Hope this helps
Mark
B
Bob_s
thanks mark..that sounds like the real fix..i'm going to try to get this to breathe a little better before i pull the engine but something tells me i'll be calling him..i can just hear the wife now as an oil leak turns into loads of 1275 hp ugrades..
markberry
Tell your wife you're going to spend the $289.00 on her instead because you appreciate how much patience and understanding she has for you and your hobby!
B
Bob_s
after almost 30 yrs she'll figure out the $289 will turn into 1k and the garage into a huge mess. in that respect they know us all too well.
J Rear Main Seal Kit Austin Healey 1
S TR2/3/3A rear main seal is leaking Triumph 13
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
S TR2/3/3A tr3 rear main Triumph 24
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
TraceZ rear main leaks Spridgets 3
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
B rear main puller Austin Healey 6
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
jlaird Installing the rear main cap cover correctly: Spridgets 3
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
