Gear oil type for 210 4 speed tranny....
Billm
I personally use common 30 weight engine oil (non-detergent if I can find it) and have never had a problem with it. Paul A (who is kind of the expert on these) uses tranny oil (90 weight) but I have found too many instances where 90 weight made these transmissions too hard to shift so I don't.
The choice is yours!
Bill
I think Rivergate was recommending Redline Synthetic MTF at one time.
scoutll
I had a 1980 210 with the 5 speed and the Datsun dealer recommended regular ATF when new. Wish I had that tranny now :cryin:
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
tinman58 Off Topic GL4-GL5 gear oil Triumph 6
S TR4/4A Trans/OD gear oil? Triumph 14
Rut GL4 gear oil Spridgets 3
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
T Gear Oil Leak Austin Healey 17
J TR2/3/3A Gear oil in the gear box? Triumph 13
Gerry M TR6 TR6 gear oil Triumph 8
A Proper Gear oil? Triumph 9
J Healey Gear Box & OD oil Racing 5
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
rkep01 Cornhead grease vs hypoid gear oil Spridgets 6
KVH GL4 Gear Oil Triumph 5
rlich8 Gear Oil Triumph 9
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
R SAE 90EP Hypoid gear oil MG 2
A Gear box oil MG 9
ekamm gear box oil Triumph 13
M Gear oil? Spridgets 4
dklawson Transmission Gear Oil - Synthetic? Triumph 7
W Silly question Gear Box oil change/top up MG 11
R Best gear oil for transmission in midget[snail] Spridgets 3
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
OregonTR4A Adding gear oil to the gearbox? Triumph 8
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
vping Rear Gear oil MG 1
A TR4/4A TR4 gear box oil Triumph 13
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
G GL-4 vs GL-5 gear oil Restoration & Tools 6
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
