TR2/3/3A TR3 Gear Oil Recommendations Needed
toysrrus
Hi Folks,
I`ll be installing the Engine & Drive Train back into my `57TR3 this weekend. We`ll be draining the Trans and Rear Axle. What is the best suited "GEAR OIL" for ea? My Trans is a "Non-Overdrive" unit.
Also; Would the same Gear Oil be OK for the "Steering Box"?
Thanx in Advance,
Russ
TR3driver
Great Pumpkin - R.I.P
Lots of opinions here, Russ. I like Valvoline full synthetic gear oil (which is rated GL5) for both the differential and the steering box; but Redline MT-90 (which is only GL4) for the gearbox. Some GL5 oils contain an additive that can attack brass components over time, but the Valvoline full synthetic does not. However, it may be too slick for good synchro operation in the gearbox; while the MT-90 really makes the synchros work great.
sail
Russ, I had noticeable improved shifting with the MT-90 after Randall put me onto it.
vivdownunder
For the rear axle, Castrol Hypoy EP90 (extreme pressure) works well. OK for the steering box as well.
I've used Penrite steering lube in the steering box for many years. Being a slumping grease, it's slow to fill and takes patience to get the box completely full (so the upper race gets lubed). The beauty of this product is that once in, it stays in. Oil often leaks from the steering box over time through the stator tube olive, leaving the upper race and drive peg dry and prone to early failure.
Redline MT-90 costs an arm and a leg down here, so many use Castrol VMX80 for the gearbox which has proven to give low wear rates in competition use.
Why a gear oil for the gearbox rather than an engine oil ?. Gearboxes don't need the cleansing and cat converter saving additives found in engine oils.
Viv.
sail
Add that after a fresh rebuild and adding OD I was using Valvoline VR1 20-50. After Randall’s suggestion and conferring with Redline the MT-90 immediately improved lazy synchro action. Yes, expensive and not locally available.
toysrrus
toysrrus
Howdy Folks,
"Viv": That was just a Typo on Gear Oil for Trans.
"Moss" sells the "Penrite Oil" for the Steering Box. It costs $17.95 for the "Bottle / Container" they show (500ml). Is that "1" Container enough to entirely fill the Steering Box or Is that a "Lifetime" supply?
Thanx for the Input Gents,
Russ
vivdownunder
Russ, I've got two partly used containers of Penrite Steering Lube on the shelf - 500 ml must have been enough per car for a fill plus overs.
Viv
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Looking for a reverse gear for my tr6 gearbox for my tr3 Triumph 7
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
af3683 TR2/3/3A TR3 Original Gear Shift Knob Triumph 16
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
ekamm TR2/3/3A Tr3 speedo drive gear needed Triumph 0
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
K TR6 Speedo gear housings :TR3 and TR6 Triumph 3
Got_All_4 TR2/3/3A Prize in every box! TR3 gear box Triumph 30
prb51 TR2/3/3A TR3 Ring gear Triumph 8
Tinkerman TR2/3/3A TR3 A Gear shift question Triumph 3
mountainman TR2/3/3A TR3 STEERING GEAR BOX FLUID Triumph 5
M TR2/3/3A TR3 Gear Reduction Starter Triumph 5
Tinkerman TR2/3/3A TR3 gear box shaft selectors Triumph 6
A TR2/3/3A TR3 gear box dismantle question Triumph 1
prb51 TR2/3/3A Gear oils for TR3 Triumph 7
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
