Tightening the idler pulley bolt on a 1098
Fred_Maves
Member
Last fall the bolt on the front of the crankshaft (idler pulley) vibrated off. It continued to churn around between the cross member and the pulley on my `59 Bugeye. It sounded like the engine was falling out. I had to have it towed and have not found time to repair it until recently. I removed the engine mount bolts and transmission bolts and have been able jack the engine up just enough to access a 1-5/16" socket. I now have a new bolt and flat washer sourced from World Wide Auto, Madison, WI. It is not at all clear how to secure (lock) the washer. There is a depression in the pulley on one side. It seems to me that merely pressing the washer into this depression would do little to secure the bolt. There is, however, keyway notch in the washer, but the woodruff key does not extend to make this of any use. So, I am thinking that lifting the opposite site of the washer to engage one of the hex facets. I plan to use blue lock-tite and some significant torque (unknown lbs.).
Any thoughts,
Fred
Knock it down into the depression for some additional insurance the washer won't spin, but the main thing is to bend over one side over one of the flats on the nut. The best way I know of doing this is to make sure one edge is angled up enough to be able to get a hold of it in the jaws or some large adjustable jaw, long handled pliers; lower jaw on a flat, upper jaws gripping the edge of the tape washer. Pul the top jaw towards you, gradually working the tab over the flat of the nut.
However, many people opt to use Loctite and skip the washer. Just make sure the threads have been well cleaned with a solvent like lacquer thinner or paint degreaser first or you'll be wasting your time. Torque is 70 ft lbs.
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
P Tightening Tie Rod Ends? Spridgets 4
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
B TR6 Tightening crank pulley bolt on TR6 Triumph 2
T Tightening spokes on wire wheels Triumph 13
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
1 Tightening spokes on wire wheels Spridgets 1
bobmga62 MGA Starter tightening up in my mga MG 6
tahoe healey Adjustable steering tightening Austin Healey 13
L Tightening U-joints Restoration & Tools 3
SHG Tightening the Ignition Nut Austin Healey 10
R Tightening rear axel nuts Austin Healey 4
S Tightening up aft tonneau/boot studs? Austin Healey 7
D Correct tightening of WW MG 0
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
T TR2/3/3A Question on steering idler unit Triumph 2
Martinld123 Steering Idler Noise Austin Healey 21
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Lutz Kramer Steering box and idler bush Austin Healey 4
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
G Steering idler arm removal Austin Healey 33
RickPA Need help installing steering idler oil seal Austin Healey 6
RickPA Clunky steering idler Austin Healey 8
C Idler Arm Differences and Rebuild Question. Need Help! Austin Healey 2
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
C Oil Seal Removal from Idler Arm? Need Help Austin Healey 4
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
S Austin Healey New Steering Idler Assembly Austin Healey 2
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
D MK2 idler arm Jaguar 6
T TR2/3/3A tr3 idler arm and shocks Triumph 2
GBRandy Wedge TR8 Idler Bearing P/N? Triumph 10
6 Problem after installing new steering idler Austin Healey 15
6 End Play in BJ8 Idler Austin Healey 2
6 Problem Removing Steering Idler BJ8 Austin Healey 9
6 How do you remove steering idler on BJ8? Austin Healey 0
6 Idler steering Assembly Problem [BJ8] Austin Healey 7
F Steering Idler Austin Healey 14
M Steering idler bushing direction Austin Healey 3
C Steering Idler problem Austin Healey 7
A How do I convince steering arm to come off idler? Austin Healey 10
N Steering Idler Box Austin Healey 3
nevets steering box and idler removal Austin Healey 14
C steering idler Austin Healey 5
S BJ8 Steering Idler Assembly Austin Healey 3
PAUL161 T-Series Dynamic Balance Pulley ??? MG 0
