TR6 Tightening crank pulley bolt on TR6
bunzil
A few weeks ago you guys came to the rescue and suggested I use an impact wrench to muscle off the 1 1/8" crank pulley bolt on the 6. I was doing this to replace the timing chain cover gasket.
Now tightening the bolt. How do I achieve the required 80 to 100 lbs of torque specified with the impact wrench? Someone lent me a 100lb Snap On torque stick but it and the impact wrench don't fit into the space provided.
I'd rather not use a torque wrench because I fear loading up the entire drivetrain might lead to damage.
Thanks
Ned
There's no way that 100 ftlb of torque is going to harm the drivetrain, Ned. After all, the engine makes more like 150 ftlb; plus there is a huge shock load when someone winds it up and dumps the clutch.
So just put it in 4th gear, lock the e-brake firmly, and torque it down.
I wouldn't use a torque stick + impact anyway, even if it would fit. They're good enough for lug nuts I guess, but just not all that accurate IMO. Too many other variables.
Thanks Randall. What you say makes sense, I was just being cautious. I torqued it up to the required specs without any issues.
Much appreciated.
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
F Tightening the idler pulley bolt on a 1098 Spridgets 2
P Tightening Tie Rod Ends? Spridgets 4
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
T Tightening spokes on wire wheels Triumph 13
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
1 Tightening spokes on wire wheels Spridgets 1
bobmga62 MGA Starter tightening up in my mga MG 6
tahoe healey Adjustable steering tightening Austin Healey 13
L Tightening U-joints Restoration & Tools 3
SHG Tightening the Ignition Nut Austin Healey 10
R Tightening rear axel nuts Austin Healey 4
S Tightening up aft tonneau/boot studs? Austin Healey 7
D Correct tightening of WW MG 0
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
