RD,
You didn't ask, but the amount that the bearing spacer ring sticks out of the hub, usually around .004" is also very critical. This dimension is set by the bearing seating depth in the hub & the spacer ring thickness.
Too much projection & the hub to axle flange joint will not seal. Too little projection, & the bearing will try to move around in the hub. The average paper gasket plus O ring will compress to about .004" which allows a perfect fit. This dimension is set by the bearing seating depth in the hub, the bearing thickness, & the spacer ring thickness.
Sometimes if the bearing is the wrong thickness or the hub/carrier is distorted, there will be less than the .004" projection. Too much projection would mean that the bearing is too thick, or not fully seated in the carrier, or the spacer ring it too thick. Spend some time measuring & checking this relationship.
The whole thing is a PIA but well worth getting right the first time.
