1098 Distributor Cap Question....
NardisCNC
Quick question. It is time for some new plug wires / dist. cap, and I noticed that there are 2 different type caps available, the side-entry screw terminal type, and the top connect press fit type. Does one style have an advantage over the other? Will they both work on the 1098? My car (66) currently has the side entry type.
Assuming they are both for the 25D distributor (the most common) they are interchangeable.
I prefer the old-style side-mount caps because my race car uses solid-core, copper wires and I like the fact that the screws make a solid "bite" into the copper.
My street MGB needs cap and wires soon too. I'll probably switch it to solid copper wires and a side cap too, because they seem more sturdy and I don't care about radio interference. The B only has a hopeless AM radio which I don't listen to anyway.
If you have a radio, then the top-mount cap with suppression wires is probably a better choice.
I use the solid wires and side cap too for the same reasons as Nial. It is nice that there is a choice though.
You're going to find that some vendors think that, because the side cap is different, that it must be rare and worth a lot of money. There are guys on ebay that try to sell them for as much as 49.00. I just keep my eyes open for them. I picked one up a month or so ago for 4.00 + 3.85 shipping.
I have a 1098 as well. I prefer the top entry cap, just for the ease of replacement. I run 90° plug wires out of the dizzy just for extra space.
(Bosch 09041)
Don't mess around and try to go cheap. Order your cap and rotor from Advance Distributor, or Peter C.. Get the good stuff.
NFI
You can also buy a ACCEL # 3009 8 cyl 7mm universal kit from the local parts store. Enough stuff for two of our cars. It is solid core and yellow.
F Swapping out original 1098 distributor to electronic Spridgets 13
R Extra 948 and 1098 Engines Spridgets 9
JimLaney 1098 stuck lifters problems Spridgets 5
F Tightening the idler pulley bolt on a 1098 Spridgets 2
Gerard 1098 10CC rear main seal conversion Spridgets 4
B 1098 motor Spridgets 2
Gerard 1098 "10CC" rear main Spridgets 0
C 1098 engine Spridgets 5
MY66AH 1098 Rebuild Spridgets 11
Gerard 1098 10CC crankshaft Spridgets 14
J Bad News 1098 Spridgets 14
Pythias 1098 worth saving? Spridgets 29
Gerard 1098 master cylinder springs Spridgets 0
A 1098 Oil Consumption Spridgets 11
T 1098 angry cc's of fury is enough to... Spridgets 4
britndablood FS 1098 with rib case in North Carolina Spridgets 0
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
M 1098 engine core-need it ? Spridgets 10
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
jlaird Need a 1098 timeing chain cover. Spridgets 12
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
M Found this in my 1098 Spridgets 14
M Do 1098 motors have fuel pumps ? Spridgets 8
M best 1098 motor to rebuild Spridgets 6
D '66 1098 Midget,,,how hard to fix partial floor? Spridgets 7
Colin8 1098 Pistons Spridgets 0
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
T 1098 valve clearance - .012 cold? Spridgets 1
T Spin-on conversion options for a 1098 Spridgets 2
jvandyke head gasket 1098 vs 1275 Spridgets 1
theleisure 1098 to 1275 swap list Spridgets 8
R Carb differences 1098 and 1275? Spridgets 6
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
T Checklist of changes to swap 1098 for 1275 Spridgets 9
Jim_Gruber Thermostat Housing for 1098 Spridgets 21
jvandyke 1098 vent tube Spridgets 77
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
jvandyke 1098 exhaust options Spridgets 43
Luke_Healey Will this oil filter convertor work on my 1098? Spridgets 14
B 1275 exhaust on MKI Midget [1098] Spridgets 3
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
tony barnhill 1098 Cam Spridgets 17
Jayrz 1098 available Denver Spridgets 2
P proper ignition wires for 1098 CG...??? Austin Healey 2
racingenglishcars Block pocketing, 998 1098 Restoration & Tools 12
HAN8L1965 coil for 65 1098 Spridgets 13
