1098 to 1275 swap list
theleisure
Bronze
I bought a '70 1275 this week and I've been reading up on swapping it in place of my 1098. I know I'll need to change to the crossflow radiator with the overflow and I know '70's came with a charcoal can for fuel loss so I'll have to get one of those. The 1275 I bought will come with a distributor and alternator. I plan on using the transmission that's on my car now. It is a ribcase from a later car (it must be-- it has a reverse switch) so that will be fine. Is there a full list of necessary parts posted online already? If not, do you guys mind helping compile the list? I have a lcb exhaust that i think will transfer to the new motor but will it work if i plan on using su's on a standard intake manifold? I'm going to collect the necessary parts slowly and do the swap eventually.
Pictures of the new 1275 are on the site in my signature
thanks,
sean
Sean - others will chime in, but I seem to remember that their was a difference in height somehow on the 1275 vs 1098..which meant a 1098 header would not work on a 1275 w/o mods(?)
You don't HAVE to switch to cross flow rad..lots of BE's running around with a 1275 and downflow. I'm performing the same swap as you (1098 - 1275) and I am planning on using the downflow. To do this, you need the original 1098 t-stat housing to get the hose pointing the right direction.
For the carbs, I'm planning on using the ones from my 1098..and I'm skipping all the emissions stuff. Sounds like you got the trans covered..
With the 1275 head, you'll have the option of placing the h20 temp sensor in the head vs in the rad on the 1098. I'm planning to just plug the rad bung.
Just remember to swap your batt cables around (if car is not neg grnd now!)
That is all I can think of. mounts are the same.
I agree with Devin, Sean, skip the emissions stuff, you can use the radiator you've got, and if you need a 1275 exhaust manifold, I have a couple in my garage we can work something out on! I would say use the KISS principal...Keep It Simple, Stupid!! :jester:
Actually, I just looked at the picture of your 1275...It sure looks like you have everything you will need right there in the pic! Just pull the 1098 and drop in the 1275!! An afternoon's worth of work!! :thumbsup:
I don't know about this stuff and haven't done it, ... but there's something about the difference between the flywheels of the two and the ribcase.. It's any easy swop, but should be addressed.
The LCB will work fine.
You'll need to change the clutch, clutch slave cylinder and slave cylinder pushrod.
You may also need to change the carb needles to get it running properly.
Also think about crankcase venting. 1275's need plenty of crankcase ventilation. Not sure how you're 1098 is set up (i.e. with or without PCV valve), but at a minimum you'll need a vent line with PCV valve running from the breather on the timing cover to the intake manifold. It's also a good idea to have an independent vent to atmosphere from the valve cover, and if you've got a mechanical fuel pump blanking plate on the side of the block, you can also add another vent there if needed.
Thanks guys, it's great to hear that I can use my current radiator and exhaust manifold if I want to.
As far as using the same carb I'm running now, I don't think I will. I have a dcoe40 on my 1098 and although that will work fine on a stock 1275, I'm a little excited about being able to use full rev range again with standard su's.
Devin, I'll update this post if I come across anything else. Keep me posted if you get to your swap first!
Thanks again,
Sean
The 1275 should mate up to the ribbed-case trans just fine! You may have an issue with the throw-out bearing though!
Hey Sean, you do not need the charcoal canister unless you just want it. most people have removed them, but if you want one I have one you can have for postage. Alan
T Checklist of changes to swap 1098 for 1275 Spridgets 9
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
jvandyke head gasket 1098 vs 1275 Spridgets 1
R Carb differences 1098 and 1275? Spridgets 6
B 1275 exhaust on MKI Midget [1098] Spridgets 3
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
Bruce_B 1275 with 1098 Transmission Spridgets 13
George Zeck 1098 v. 1275 engine transplant ?? Spridgets 13
R Extra 948 and 1098 Engines Spridgets 9
JimLaney 1098 stuck lifters problems Spridgets 5
F Tightening the idler pulley bolt on a 1098 Spridgets 2
Gerard 1098 10CC rear main seal conversion Spridgets 4
B 1098 motor Spridgets 2
F Swapping out original 1098 distributor to electronic Spridgets 13
Gerard 1098 "10CC" rear main Spridgets 0
C 1098 engine Spridgets 5
MY66AH 1098 Rebuild Spridgets 11
Gerard 1098 10CC crankshaft Spridgets 14
J Bad News 1098 Spridgets 14
Pythias 1098 worth saving? Spridgets 29
Gerard 1098 master cylinder springs Spridgets 0
A 1098 Oil Consumption Spridgets 11
T 1098 angry cc's of fury is enough to... Spridgets 4
britndablood FS 1098 with rib case in North Carolina Spridgets 0
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
M 1098 engine core-need it ? Spridgets 10
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
jlaird Need a 1098 timeing chain cover. Spridgets 12
M Found this in my 1098 Spridgets 14
M Do 1098 motors have fuel pumps ? Spridgets 8
M best 1098 motor to rebuild Spridgets 6
NardisCNC 1098 Distributor Cap Question.... Spridgets 7
D '66 1098 Midget,,,how hard to fix partial floor? Spridgets 7
Colin8 1098 Pistons Spridgets 0
T 1098 valve clearance - .012 cold? Spridgets 1
T Spin-on conversion options for a 1098 Spridgets 2
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
Jim_Gruber Thermostat Housing for 1098 Spridgets 21
jvandyke 1098 vent tube Spridgets 77
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
jvandyke 1098 exhaust options Spridgets 43
Luke_Healey Will this oil filter convertor work on my 1098? Spridgets 14
tony barnhill 1098 Cam Spridgets 17
Jayrz 1098 available Denver Spridgets 2
P proper ignition wires for 1098 CG...??? Austin Healey 2
