Block pocketing, 998 1098
racingenglishcars
Many people want to make their 998 or 1098 a-series go a bit faster, but the 12G295 heads appear to be rather expensive. The alternative is to install a 12G940 head from a 1275, which is a wonderful head for the price (used of course). Problem is, that the exhaust valve hits the block, just a little bit. There are some ways to get around this. Sink the valve and use a standard cam is one way, but for any good performance one needs to use a high lift cam and pocket the block. This can be rather expensive as normally the engine must come out and sent to the machine shop. Another alternative here is to grind it while in the car... by hand?? NO, but maybe this tool I drew up would do it. Just use a bit of oily cloth in the cylinder to catch the dust and a 36mm face-mill and grind it by hand.
https://i183.photobucket.com/albums/x288/frogeye61/Links/BMCTOOL1.jpg
https://i183.photobucket.com/albums/x288/frogeye61/Links/BMCTOOL2.jpg
https://i183.photobucket.com/albums/x288/frogeye61/Links/BMCTOOL3.jpg
https://i183.photobucket.com/albums/x288/frogeye61/Links/BMCTOOL4.jpg
https://i183.photobucket.com/albums/x288/frogeye61/Links/pocketblock.jpg
Would anybody like to make it and try it out? Then you can lend it to all us needy people who want to pocket our block.
I've done this type of thing on 948 race motors with high lift racing cams, but not with that big of valve. A few things to think about, will the 1098 head gasket with a 1275 heed clear the valve, or do you plan on using a 1275 head gasket, and does that work out as well. Then another thing to think about with valve notches in the block, is you need to make sure the first ring land is low enough that the top ring doesn't make it up that far, you may need special piston, in the 948 race motors we made custom pistons with this change made to them. Also I would look for about .100" valve to block clearence as a minumum.
Hello Don,
1098 Morris Minor.
I made up a mandrel to which I fitted a grindstone, machined to the correct diameter. The mandrel went through the exhaust guide and with the head in place I ground the pockets using an air powered die grinder.
As this was with the engine in the car I carefully sealed the bores with rags and grease. Worked fine and I do believe I used a 1275 head gasket.
Alec
Gesh, you guys are technical marvals and I only want my rings to seat. sigh
Relieving the bore for valve clearance really screws up the gas flow. What you MIGHT gain in a larger ex. valve you WILL loose in the screwed up gas flow.
That said, and using an exhaust valve that needs bore pocketing, you MUST register the cylinder head to the case as you want just the bare minimum of valve edge to case distance. The stud holes in the case have (usually) two register holes and the others are a lot larger than the stud diameter. But.....the head still walks around ...try it when you lay the head with the studs in the case.
The answer is to dowel the head to the case but thats a pain to do a match dowel. Easier is very thin wall sleeves (2), one in each end of the head and a slight interference fit in the cyl head hole.
The 948 has the bigger bore and is not so problematic. But still, using a custom piston with a high top ring placement your dead in the water. Moving the exhaust valve guide over toward the intake side is the better alternative. You still have to deal with rocker/pushrod angularity and geometry if you move the valve. At the end of the day a larger exhaust won't get you much out of the ol' horsepower slot machine.
Hap sez.............
"" A few things to think about, will the 1098 head gasket with a 1275 heed clear the valve, or do you plan on using a 1275 head gasket, and does that work out as well. """
And Haps right of course.....and think you must with that combo of using a 1275 h.g. with a small bore motor. You will have a ton of dead air with the larger 2.875" (+ -) bore h.g. on a 2.540" motor. More horsepower lost.
Just another thought....offset bore the case toward the exhaust side.....
Hello all,
the gain from using the 12g940 head outweighs any of the theoretical drawbacks mentioned particularly over the 12g202 fitted as standard to the 1098 engine (Minor). A 12G295 requires no modification but are not as plentiful.
Jerry, the amount of walk you refer to is negligible in view of the task at hand. Offsetting the bore, apart from the expense is not practical as the valve overlaps by about (and this is from memory a few years ago) 0.250" to 0.300". I doubt that there will be that much metal.
Alec
How does one identify what head(s) they have? i.e. where is the number found?
Mike, the casting number is found on the upper surface of the head, under the valve cover. I can snap a pic for you when I get home tonight.
Jeff
Just posted this in another thread...Jeff, you might recognize this one:
Ray
Looks familiar, Ray. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
The 206 head I have handy has the numbers in the same spot. The 202 has them between #1 & #2 intake valves.
Jeff
sim A-series Engine Block Search Spridgets 2
B TR6 71 block & crank Triumph 1
T Block Heaters Austin Healey 3
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
R For Sale 100 engine block w/head Austin Healey Classifieds 3
Sopwith_Camel what is this on the block? Jaguar 13
BoyRacer Mystery 3000 Engine Block Austin Healey 2
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
P TR2/3/3A Block treatment post cleaning Triumph 17
Bayless Ready for final block sanding Spridgets 5
Joel Lester TR2/3/3A "TR3" painted on the engine block Triumph 13
R Rust in Block? Help needed! Austin Healey 6
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
nichola TR6 Classic Technologies front sealing block Triumph 7
nichola TR6 Aluminum block engine Triumph 8
M 948 Cylinder Block Studs - Sequence on Cylinder Block Spridgets 4
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
F TR2/3/3A SU 1 3/4 Carb to Manifold Insulating Block; '59 TR3A Triumph 6
Bremer TR2/3/3A Block deck height? Triumph 10
Bayless Memory block Spridgets 3
D TR2/3/3A Coolant tap on TR3 block Triumph 3
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
T Oil filter block plate - really? Austin Healey 13
6 1275 Head to block dowel pins Spridgets 10
D New Fuse Block Configuration Austin Healey 21
Sarastro TR4/4A Engine block deck flatness Triumph 9
KVH TR4/4A Block Water Outlet Valve Triumph 13
D 3000 engine block Austin Healey 0
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
S BJ7 frozen temperature sensor to block Austin Healey 17
D mystery of the day... pedal block? Austin Healey 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
simon1966 Numbers stamped into a BN1 block? Austin Healey 5
M TR6 Front sealing block Triumph 11
H Post-War Other Herald rear suspension lower block installation Triumph 3
D Engine Block Austin Healey 14
jfarris TR2/3/3A Head stuck on block Triumph 8
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
J Austin healey block Austin Healey 18
Zitch TR4/4A New fuel pump fitment to block Triumph 3
M About alternator bracket and cylnder block interface on BN1 Austin Healey 9
