nathandarby67
Hi all. I've got a 1973 Midget, and just finished putting on new coil/points/condensor/rotor/cap/plugs/wires/etc. I finished adjusting the valves, and now need to time the car. The engine is stock except the air pump and related junk have been removed. My shop manual says to set the static timing at 0 degrees, or in other words right at TDC. however, for 1275 midgets made in 1972 and earlier it lists 5-7 degrees BTDC. I was wondering if my car's recommendations are different because of the introduction of emission controls? Now that there is no air pump, should I advance my timing more? What static and dynamic timing settings have others found work the best?
Also, my shop manual shows the timing pointer on my car as having 3 points on it, however my car has a timing pointer with 5 points like on an MGB. I assume the first pointer is TDC, and the others represent 5 degree increments BTDC. Anyone know if this is correct?
THANKS!!
THANKS!!
