Not sure what happened to this one. One week it was fine, the next the clutch wouldnt engage far enough to put the car into gear. I looked under the car and the lever moves, but when the clutch pedal isnt depressed i can easily push the rod all the way in and all tension on the clutch pedal is gone. I bled the cylinder to make sure all air was out and it is, but the fluid looks milky. However, it does not appear that way in the reservoir. The car hasnt been anywhere that water or anything else would contaminate the fluid. I suppose a gasket failed internally in the slave, but there aren't any leaks. Time to take it off and check it out i suppose.
