TR2/3/3A 1961 TR3 turn indicator diagnosis?
Kleykamp
Left turn signal works as it should. Right signal flashes at green indicator on dash but neither front or rear indicators come on. I visually inspected both bulbs and they appear ok. Flasher unit seems warm to touch. There seems to be a heavy draw on power when the right signal is trying to work, i.e. ammeter bottoms out as light on dash flashes, and the generator light dims. Did I say I hate electrical issues. I suspect the flasher unit, even though it is relatively new, i had about 3 of them before getting one to work. But, in the process of trying to get a squeak out of the adjustible stearing column, I pulled the control head back about 3 inches accidentally. I'm thinking if the wiring there shorted out, there would not be power at the flasher unit though. Did I mention I hate electrical issues? Elementary school version on answers please. Thanks in advance as I know someone will know how to check this through.
mallard
Did you install a new wire harness? I did on mine and could not get the right turn signals to work. I did find I had power coming out of the control head for both right and left so I knew it was not the control head. Two of the wires that come out of the control head green-brown, and green-red were very close in color and I had them connected wrong. After I switched them all the lights worked fine.
TR3driver
Great Pumpkin - R.I.P
"Left side works" says that it is unlikely to be anything common between the two sides, like the flasher unit. The ammeter behavior says that you have a short somewhere in the wiring between the switch contact in the control head, and the RH turn signals.
Electrical shorts can be tough to find. Since you suspect the control head, I would probably start by disconnecting the RH circuit where it comes out of the stator tube (near the LH horn). Find the harness with 4 wires that runs through the stator tube. Hopefully, you'll be able to see the color codes to look for the Green/White wire. If not, look for the thin wire that joins with two other wires in a 4-way connector, and both of those other wires go into the main harness. (The heavy wire is for the horns, and one of the GR wires goes to the LH turn lamp instead of into the harness.)
Disconnect the GW wire from the 4-way sleeve and test again. The left turn signals should still work (if not, you probably got the wrong wire). If the ammeter still pegs when you select right turn, then the problem is in the control head or the wires in the stator tube.
If you're lucky, one of the connectors inside the control head is just bent and touching something it shouldn't be touching.
Kleykamp
Kleykamp
I'll test the wires out of the stator tube and see. Everything was working fine yesterday and then I went to lube the adjustible column and the control head came out of the stearing wheel. My control head is just about literally made with JB weld and super glue so it is extremely suspect to start with. Could be the little brass screws I used to make the contacts inside the head. The horn quit working about 2 months ago. May be time to break over and buy one, but I'll check wires first. Thanks
Kleykamp
Kleykamp
Randall called it right...as usual. When I "rebuilt" the control head, the brass ring that makes the horn contact was broken. I put a wire across to complete the circuit which did work for a while and the horn worked. The horn quit working about 2 months ago. I guess when I pulled the control head up it moved the flasher contact which was touching and shorting against the horn contact... if any of that makes sense. What I need is the brass ring that goes to ground to fix the horn. Otherwise, I can put it back together without the horn contact and the flashers will work fine. Since the horn contact is not available...to my knowledge, I'll probably need to buy the whole control head to have everything working. Hate to buy a $200 control head for a 50 cent brass ring. I'm going to post separately about the horn contact. Maybe someone has some parts around on a otherwise bad control head.
Kleykamp For Sale 1961 Triumph TR3 Triumph Classifieds 0
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
3798j TR2/3/3A My 1961 TR3 - Class of '67 Triumph 6
S TR2/3/3A 1961 tr3 conversable top rib color Triumph 7
P TR2/3/3A 1961 TR3 for sale On web Triumph 6
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
Dave_H TR2/3/3A 1961 TR3 4 Sale - Too good to be true? Triumph 4
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S Wanted The Autocar December 1, 1961. Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
N General MG 1961 mg MG 14
kodpkd 1961 BT7 engine oil Austin Healey 31
Hamish Racing 1961 vintage car film UK Racing 6
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
D TR2/3/3A 1961 Triumph TR3a Triumph 17
T For Sale 1961 Austin Healey BT-7 for sale Austin Healey Classifieds 1
T For Sale Tr3a 1961 Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
P For Sale 1961 Bugeye Sprite Spridgets Classified 0
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
I 1961&62 Mk2 sprite roofs Spridgets 1
G original radio 1961 e series jaguar Jaguar 3
S TR2/3/3A 1961 Triumph TR3A - Light issues...likely issue? Triumph 5
longbridgehealey 1961 Nash Metropolitan Spotted 2
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
arcom TR2/3/3A Decent 1961 TR3A on BAT Triumph 11
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
R old [Austin Healy 1961 sprite] vs new [Peugeot 306] hill climb youtube[TopGear] video Spridgets 4
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
Italia 227 Post-War Other 1961 Triumph Italia 2000 GT – new member Triumph 19
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
Hot Wings 1961 Austin Healey 3000 BT-7 4 sale Austin Healey 10
NutmegCT MGA Motor Trend 1961 Review of MGA 1600 MkII MG 8
C 1961 3000 Restoration Austin Healey 132
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
R TR2/3/3A Tr 3a,1961/62..anyone interested? Triumph 3
N TR2/3/3A 1961-TR-3 Transmission Fluid Triumph 4
N TR2/3/3A 1961-TR-3 Choke Return Spring Triumph 1
AUSMHLY 1961 Austin-Healey Sebring Sprite Lightweight Work Austin Healey 0
E TR2/3/3A 1961 TR3A Engine Color? Triumph 7
C 1961-1962 Sprite, What chasis and Frame? Spridgets 4
H CUMMINS TURBO DIESEL CAR 1961 PLYMOUTH Other Cars 2
Monark192 $100 for 1961 Midget on Craigslist Las Vegas Spridgets 4
