MGA Motor Trend 1961 Review of MGA 1600 MkII
NutmegCT
For you history buffs - Motor Trend's review and road test.
"Erecting the top is not a detail that can be completed by one man while remaining seated in the car."
https://docs.google.com/file/d/0B5xnnKbPEWx5OUhiQ0RBZUhRWDQ
Tom
PS - I tried uploading the pdf file (9.3MB) to BCF, but after uploading, the only options on the window were "upload a file" and "drag file after uploading". Gave up after 30 minutes and moved the pdf to Google docs. Hope this works.
billspohn
On a lot of old British cars you'd have to go get the top out of the boot to erect it. The TR-3 for example, and my MGC which has both the top and top bows stowed in the boot (an optional attached soft top with bows was available).
urchin
My '63 MGB had a tent-style top, as did my '63 Triumph Spitfire. Both had to be stored in the trunk and reassembled on the side of the road, generally in the rain :smile:. But even my '80 TR-7 convertible required me to get out of the car [in the rain] and walk around it snapping the top in place. Only my '72 Fiat Spider and my '64 Corvair Monza had tops you could erect by lifting them into place and clipping the windshield clips in place - no snaps :smile:.
Jeff
Sarastro
Back in the '60s I had a TR4A, and you really couldn't raise the top without getting out and exerting some degree of effort. Maybe some gorilla could put it up without leaving the car, but I couldn't. It had a "modern" top, not a tent one.
My bugeye Sprite, which I sold a couple years ago, had a tent top. It came with the car when I bought it, but it hadn't been installed. I installed it, and drove around with it once, then took it off; too claustrophobic, and, after all, this is CALIFORNIA, for heaven's sake! It doesn't rain here!
drooartz
I liked the top on the Bugeye -- simple enough to put up. I considered it "cozy" rather than claustrophobic. I had the later Michelotti top on my old MGB; it sealed up nicely but was a bit of a struggle to get put up.
With both cars I did feel like I was driving around in a little pup tent, but then I like tents. :grin:
MarshgrassA
I could not open the file but then I can't put the top up on my 61 MGA without a lot of help either! 1st time my husband tried to help me I somehow got his fingers pinched in the frame. Not a good thing to happen.
My TR4A is fairly easy and I can put that up without help and I remember my 66 B being such a pain that I would just leave the whole top off and chance the weather.
These old LBC's are supposed to be an adventure.....
aeronca65t
I converted the fold-away top on my '69 MGB to the earlier style (which means the top now comes off the car and the erector set type frame goes in the trunk). It looks good up and when it's off, the car looks very "clean" in terms of appearance.
But it's a pain in the neck to put up or down. Probably takes me 15 minutes to do it properly. I only do that a few times a year (it's been off all Summer for the last few years).
My '73 Midget has a folding, canvas top. It's about 15 years old and I try to be careful not to crack or crease the plastic windows. I would not take it down in cooler weather because I'm concerned about damaging it.
My Miata has a glass rear window and the top goes down in about 10 seconds even with the roll bar. It's a great design. Mine has the original top (14 years old) and it really needs to be replaced (I've patched it where it has cracked).
The ~Super 7~ I just bought has a top that seems even worse to put up or down than my MGB. I'll probably never use it. :friendly_wink:\
I remember the MGA top even though I owned that car when I was 17 (44 years ago!). By the time I was 18 I also owned a TR3. Both tops were in dreadful shape and abysmal to put up or down. I loved them both!
billspohn
Geez - 44 years ago I also owned a TR-3 and an MGA, and I was the same age!
We both must be crazy!
NutmegCT TR2/3/3A TR3 - Motor Trend magazine, 1956 Triumph 2
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
B TR4/4A Rubber wiper motor mounts Triumph 4
R Rewind electric motor Restoration & Tools 3
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
R GT6 Wiper Motor problem and time capsule Triumph 4
K TR2/3/3A Motor oil for Summertime Triumph 3
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
steveg Motor mount replacements Austin Healey 3
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A starter motor Triumph 9
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
Michael Oritt Heater motor or switch problem Austin Healey 1
sparkydave Wiper motor '77 Spridgets 2
