TR4/4A Routing of wiring harness to the rear of a 1961 TR4
Gerald_Gordon
Member
While my TR4 is having its carpet and vinyl interior replaced at a shop in a distant state, I would like to add additional wires to the harness between the front and rear of the car. Could anyone say whether this harness runs above the floor and beneath the carpet or beneath the floor, please? Photographs would be welcome.
trrdster2000
On the floor beside the door opening, into the hole behind the "B" pillar, over the inter fender and into the trunk area. The gas tank sender comes out at the top of the inter fender along with the trunk light, if you had one on a 4. Should be on the left side as you are sitting in the car. The voltage stabilizer is in the top of the passenger foot area on the right side.
Wayne
Gerald_Gordon
Gerald_Gordon
Member
"...The gas tank sender comes out at the top of the inter fender along with the trunk light, if you had one on a 4. Should be on the left side as you are sitting in the car.... Wayne"
Wayne, wiring a trunk light is exactly what I want to do. Thank you very much.
trrdster2000
If you are going to use a toggle switch, get one with a light showing it's in service. If you are going to do the TR6/Spitfire type ground, Might have to rig up a bracket for the switch to hit. Never was a fan of that switch, or the excuse for a light. A string of LED's might at least light it up when you need it.
Wayne
malbaby
As above.....the harness can be hidden under the separate carpet piece that runs down from the door opening....assuming that the carpet piece is cut wide enough.
Are you planning to carpet the car as per original configuration, or custom fit as one piece on each side from the back to the top of the footwell....[ I fitted as one piece ]
Also, consider altering your outer seat belt fixing position. I moved mine forward slightly so that the metal attachment did not impact on the vinyl on the adjacent wheel arch.
Gerald_Gordon
Gerald_Gordon
Member
Malbaby, thank you for the advice about leaving space adjacent to the underlayment which, in my case, will be Dynapad four‑part, composite-barrier, constrained‑layer material https://www.dynamat.com/automotive-and-transportation/automotive-restoration/dynapad/ instead of the standard jute, which I hope would absorb some of the low-frequency droning that is quite loud at 3000 RPM when the hood is installed and the windows are closed. The carpet itself is a standard grey Wilton-wool kit from Rimmer Brothers that I bought during the recent sale. Beneath the Dynapad underlayment will be Dynamat Extreme damping material https://www.dynamat.com/automotive-and-transportation/automotive-restoration/dynamat-xtreme/ stuck directly to the floor, firewall, and driveshaft tunnel to suppress resonances in the sheet metal.
Of the two new wires, one is for an existing after-market light in the boot that is activated by the opening of the lid but that presently has power to its switch only when the tail lights are illuminated, and the other is for a future backup light if I could find something inconspicuous, such as a narrow strip of white LEDs mounted discreetly beneath the bottom edge of the rear panel. (Recommendations are gladly welcomed.)
Thank you for your advice about the outer seat-belt anchors. As part of this project, my lap belts will be replaced with a three-point (UK: "lap-and-diagonal") system. When I last drove the car in June, I had not noticed any interference between the outer attachments and the vinyl on the wheel arches, but I will examine that when I again have the car in a few weeks.
Geo Hahn
Something you might consider - I added bullet connectors to the wiring for the license plate lamps inside the boot on both sides. This allows the bumper to be removed and installed without having to remove the fiddly license plate lamp fixtures each time.
Sarastro
For what it's worth--this is a '66 TR4A.
Gerald_Gordon
Gerald_Gordon
Member
Geo Hahn and Steve Maas, thank you both for your photographs, which will help me visualize the harness routing when I discuss it with the upholstery shop in a distant state.
Healey Nut Wiring Harness Routing Austin Healey 5
B TR6 Reverse light wiring harness routing Triumph 4
M Wiring Harness Routing Austin Healey 13
Nelson Wiring harness routing? Spridgets 9
Nelson Routing of wiring harness Spridgets 2
jjbunn Driver footwell rear wiring harness routing Triumph 13
chicken Wiring harness and fuel line routing Austin Healey 15
C Wiring sub-harness routing Austin Healey 8
Healey Nut Rear Wiring Routing Austin Healey 2
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
Nelson Front wiring routing Spridgets 7
T Details on wiring routing Jaguar 4
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
S Routing of Hand Brake Cable Austin Healey 6
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR4/4A What is the routing for the speedo cable Triumph 2
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
AHS TR2/3/3A Disc brake line routing Triumph 0
