TR6 Routing Speedo cable for a J type tranny in my TR250
Got_All_4
Got my tranny in and now trying to decide what is the best way to route the speedo cable. I do have a 90* adapter and a 73" cable. Figure it's got to be the same as a later TR6. Not sure if going under the tranny or over it and the back side of the engine.
Madflyer
Try to get a high temp grease that will not melt or separate or Lithium. Pull the cable out of housing and wipe lube as you slid it back in, a light film is all that is required with a smooth bend gauge should hold steady. Madflyer
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR4/4A What is the routing for the speedo cable Triumph 2
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
M BT7 Speedo Cable Routing Austin Healey 3
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
R MGA Speedo cable routing MGA MG 2
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
S Routing of Hand Brake Cable Austin Healey 6
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
AHS TR2/3/3A Disc brake line routing Triumph 0
M TR2/3/3A OD wire routing question Triumph 14
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
