TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A?
TuffTR250
The fuel pump on my 1961 TR3A is very difficult to get installed due to interference from the big steering column bracket next to the firewall. Today my son and I were hopefully going to start the car for the first time. The first step was to make sure the fuel pump was pumping gas to the carbs. Yuk, no gas to fuel pump bowl. When I tried to move the priming lever on the fuel pump it would not move. We concluded that I had installed the fuel pump incorrectly. As we pulled the pump out quite a ways, I could then move the priming lever. So we assumed that the pumping arm on the fuel pump had gotten under the cam shaft lobe instead of up against it. So we tried to reinstalled the fuel pump again but every time we tried to tilt the pump to prevent the pumping arm from going under the cam lobe, the fuel pump would bump against the big steering column bracket and prevent us from tilting the fuel pump to get the pumping lever in correctly against the cam lobe instead of under it. Do I have to remove the big steering column bracket in order to tilt the fuel pump up on the engine end to ensure the pumping arm does not go under the cam lobe? That seems a drastic step. Thanks for the help!!!
Regards,
Bob
TR3driver
Great Pumpkin - R.I.P
Try turning the engine one revolution. That will move the cam lobe away and give you more room. ISTR that once holding the priming lever up at the same time made it slide right in.
mrv8q
Come on, 13,000!
T
TuffTR250
Thanks Randall! I'll give that a try. We did pull up on the priming lever while inserting the fuel pump, but I had not thought about making sure the cam lobe was away from the engine hole. I may even try wiring the priming lever up while the pump is out of the car, if I can get a wire around it.
Regards,
Bob
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
pbraun Alex Moulton's special Mini Moke for sale Other British Cars 0
Sherlock A special Ferrari replica Other Cars 5
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
O Wanted MG K/KN to K3 special MG Classifieds 3
Michael Oritt Special tools for LBC'S Austin Healey 25
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
M Jaguar XK Special Equipment Generator Jaguar 1
R TR6 Transmission Removal Anything Special To Know Triumph 9
P Special Sockets Restoration & Tools 6
C TR2/3/3A TR Special Triumph 7
C TR2? Special Racing 3
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
aeronca65t Henry Manney Special Spridgets 23
C BMC Special Tuning Data Austin Healey 9
PAUL161 Boyal Special-1938 Maserati 8CTF Racing 0
aeronca65t Mustang Calif. Special Spotted 5
M 60s jaguar based special Jaguar 2
3798j Fitch-Whitmore Jaguar Special Jaguar 3
JPSmit Land Rover Defender - and Home made special Spotted 1
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
aeronca65t John Pope Special Other British Cars 4
aseriesspares Triumph - Complete Hardware Sets! SPECIAL OFFER! Triumph 0
aseriesspares Spridget - Complete Hardware Set! SPECIAL OFFER! Spridgets 0
aseriesspares MG - Complete Hardware Sets! SPECIAL OFFER! MG 6
aseriesspares AH Sprite -Complete Hardware Set! SPECIAL OFFER! Austin Healey 4
aeronca65t Vintage Homebrew Special Other Cars 3
RickB No LBC - can't find a special bolt - help? Spridgets 21
C The Story of a Very Special Jaguar Racecar Jaguar 2
C Very nice Triumph-Powered TVR 2200 Special Racing 9
BobbyD Hemmings Looking for Special E-Types to Honor Jaguar 0
rick_ingram Special MOSS deal for MG2011 registrants! MG 1
Hap Waldrop VTO Spring wheel special Triumph 4
Hap Waldrop VTO Spring Wheel Special Spridgets 9
Hap Waldrop VTO Spring wheel special MG 1
B Midget 50th - SS Badger special rate expiring! Spridgets 1
G Not another Andrew Mace Special! ! ! Triumph 14
S Healey Special Austin Healey 4
JPSmit Triumph Special Other British Cars 1
Sherlock Lancia, a rather special one... Spotted 3
Hap Waldrop VTO wheel Christmas special Spridgets 35
aeronca65t Neat Old Special Other Cars 3
DNK Special Sale about to end Triumph 5
T OT - A special Happy 4th to our Veterans here Triumph 3
UmmYeahOk VB Winter Special Deadline Triumph 2
S TR2 Gibbons? special... does anyone know anything? Racing 2
Brosky Harbor Freight Tools New Years Day Special Triumph 5
L Special Tuning PDF Spridgets 4
Bob Claffie Tag sale special Spridgets 0
