clutch slave cylinder?
mtlman8
Does anyone have a photo of where the rod goes into the cylinder? when rebuilding mine it looks like someone cut,welded and ground down the end of it... should it look the same as the master cylinders? (rounded head with a washer that does not slip off)any info would help. THANX.oh yah 67 tr4a ...duh!
TR3driver
Great Pumpkin - R.I.P
Sorry, I don't have a photo that shows that. But there is no rounded head, no washer, no circlip. The end of the factory rod is just rounded, no larger than the shaft. And only the resistance from the clutch keeps the whole thing from coming apart.
M
mtlman8
thanks randall, Thats what I thought, but I think a previous owner added some weld to build it up because its adjusted all the way out and its a real crappy weld job... I think i'll just reweld it grind and polish it CORRECTLY! THANX.
TR3driver
FWIW, not being a welder, I found it easier to just fabricate a new one. Started with some plain 5/16" rod from the hardware store, ran a 5/16NF die down one end, then cut to length and ground a radius on the other end.
In my case, the root cause turned out to be a broken taper pin; but I limped by for a year or more with the longer pushrod. The tip of the broken pin was jammed between the fork & shaft, so the clutch still worked even though the lever was farther to the rear than it's normal position.
M
mtlman8
did you use stainless steel or mild steel? I can buy a ss threaded rod and round and polish it.
TR3driver
I used ordinary mild steel, but no reason SS wouldn't work.
K New Clutch Master/Slave Cylinder Austin Healey 1
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
R clutch slave cylinder Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
G MGB Clutch Slave Cylinder MG 34
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
Darrell_Walker TR4/4A TR4A clutch slave cylinder adjustment Triumph 2
Hairyone clutch slave cylinder Spridgets 14
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
T TR4/4A TR4A clutch slave cylinder Triumph 9
B T-Series Clutch slave cylinder MG 15
mountainman tr 3 clutch slave cylinder Triumph 7
T Any tips on bleeding the clutch slave cylinder? Triumph 6
Bruce_B Anyone have a picture of Clutch Slave Cylinder.... Spridgets 4
JPSmit Qucik Question #1 Clutch slave cylinder Spridgets 2
Michael Oritt Clutch slave cylinder ID help needed Spridgets 3
Michael Oritt Clutch slave cylinder ID help needed Racing 3
MadRiver Speedbleeders for Clutch Slave Cylinder Triumph 3
6 clutch slave cylinder Triumph 2
tony barnhill Clutch Slave Cylinder Spridgets 17
roofman TR6 Tr6 clutch slave cylinder replacement Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
L T-Series Clutch Slave Cylinder Tubing MG 5
danielnorton After Marke slave cylinder for clutch hydraulics? Spridgets 20
SherpaPilot Clutch Slave Cylinder Mount Position Triumph 4
O Clutch Slave Cylinder Travel Triumph 5
T Clutch slave Cylinder HELP Triumph 3
M TR4/4A TR4 CLUTCH SLAVE CYLINDER Triumph 2
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
Slider748 Clutch slave cylinder question. Help! Triumph 8
F clutch slave cylinder Austin Healey 12
W Clutch Slave Cylinder. Triumph 2
Alan_Myers TR4/4A TR4 clutch slave cylinder - stuck! Triumph 14
