TR2/3/3A Fuel Pump???
Skidude
Recently had my carbs rebuilt. Since the rebuild - if the car sits for more than a couple of days - it is very difficult to start. It's like the car has kept no fuel in the bowls - like it has to pump gas from the tank, through the lines, the pump to the carb bowls until they finally fill up and then the car will sputter and start.
Never did this before - and there are no fuel leaks I can find anywhere.
Could this be a fuel pump problem that is causing some sort of vacuum that is sucking the gas back to the tank?
equiprx
You can find check valves at any hardware store or auto parts supplier.
Just make sure they are fuel safe.
LarryK
Alcohol fuel will dissapate from a fresh stopped engine and evaporate. Pull fuel and see if fuel is pumped at start. If fuel pump has a pump handle on it prime first, then see hiw it starts.
DavidApp
Check the rubber gaskets where the fuel bowl attaches to carburetor. They can be difficult to get sealed. There could be a very slight leak threre. Touch the bolt holding the bowl looking for any signs of gas.
David
CJD
To answer your question..."no", fuel cannot suck out of the bowls. It just evaporates. That's also why the OEM pump has the manual lever. If your car sits more than a week, you can save a lot of cranking by using the manual pump lever. If you don't feel like popping the hood to manually pump, then consider the long cranking normal after a long sit.
CJD
I'm with you, Geo. I used to religiously pump up the fuel bowls...but the last few years I just let them crank up.
Sarastro
This has always been a big issue in early Porsches. One common solution is to insert a priming bulb into the fuel line--like one of those thingies used with outboard motors, and use it to prime the carbs before starting. I think that looks stupid, but it's done a lot. Another is to include an electric fuel pump, which is used only for priming. Again, that makes no sense to me--if you have the electric pump, why use the mechanical one at all?
My solution in the Porsche 912 and in my TR4A is to have an electric fuel pump that has a rated pressure a little higher than the old mechanical one (say, about 6 PSI) and to use a Holley regulator to adjust the pressure to a nice, consistent ~2 PSI at the carbs. If the car has not been run for a while, I turn on the ignition, wait a minute for the float bowls to fill, and start the car.
LarryK
Electronic fuel primer is good.
sp53
I believe the chokes are not set correct. Pull the choke out and then look down and see how far the jet pulled down. The front jet depending where you live needs to come down at least ¼ inch when the joke is pulled.
steve
Jim_Stevens
I‘ve begun to pump the fuel pump lever nowadays if the car sits for awhile. Any idea how many times I should do this? Jim
mastaphixa
Bronze
You should be able to feel when the bowls are full and the float valves close. You can't hurt anything by pumping too many times but 7 or 8 strokes should do it.
RGK
A video showing proper procedures, actual start begins at 8 minutes in.
LarryK
Just as easy as a British Car tuneup. 100 mph for 3 miles after warmup, cool down and return to barn. Keeps them clean and ready.
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
