I had recently rebuilt an engine for a triumph spitfire and, when the fuel pump was installed it did not work. My question is is the spacer for the fuel pump needed. I had put a new cam shaft in maybe the lobe on the cam is smaller not activating the pump? I had bought a new pump and it seems to be the same size (lever) and it doesn't work either.
Thanks
Thanks
