new mecahnical fuel pump not working
  • Thread starter Deleted member 9684
  • Start date
Deleted member 9684
so i started up the bugeye last week and waso going to take it for a ride when i noticed the mechanical fuel pump leaking profusely. rather than screw around, i jsut order the replacement from Moss and installed it yesterday. figured it would be an easy swap and it was until i started the engine. it ran for a minute as it emptied the SUs and now will not start.
I disconnected the output from the pump and turned the engin over and as i expected, nothing comes out. Any idea what i've done wrong?
this is a 61 BE with a 948 - no mods whatsoever and not interested in making any. :smile:
nomad
Hi Seano.....The replacement pump does not have the little lever to prime the pump unless they have changed. I have a new one around here somewhere and that is the way that one is. I'm betting that the pump has not gotten primed yet and that it will work if you can just get the air block out. How to do that has me stumped but if you had a full tank of fuel I would bet it would be easier.
Kurt.
Deleted member 9684
thanks kurt, i was thinking the same thing. wonder if I submerge it in a small jar of fuel before installing it if that would help??
dklawson
I cannot provide specific details but I know that through the years of A-series production a couple of differrent mechanical pumps were used. I know the difference involves the length of the pump lever arm. It could be that the replacement pump is a later type that needs a thinner spacer for the arm to contact the cam.
Deleted member 9684
thanks doug. the housing on teh new pump is about 1/4 thicker than the old. i negelected to compare the length of the arms when i did the swap, so that will be the first thing i look at when i pull the new pump back off.
dklawson
I may have presented you with a red herring. I went looking for information on the fuel pump arms. I know I have seen it somewhere in the distant past but what I found online today says the main change was when BL replaced the A-series with the 1500 Triumph engine which uses a very different fuel pump.
While I would certainly compare the new and old pumps (assuming you have still have the old one) I would not presume what I told you earlier was correct.
nomad
If you still have the old pump I wouldn't throw it away. Don't know if there is a kit made to repair them but they are pretty simple and if its just a failed diaphragm you could probably find some of the material and make a new one.
Kurt.
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
