General TR D Type overdrive not working need suggestions
JKB1957
I was out on a drive a couple of weeks ago and the O/D in my Spitfire stopped. Got home, looked under the dash and plugged the O/D wires back together, and still no O/D. So out with the trans tunnel. First check, wires are all connected as they should be. Step two, oil is full, 30 wt, non-detergent. Step three off with the side over, adjust actuating level, make sure solenoid working it should. Step four pull operating valve, clean, replace spring.
Test drive today, car ran perfect, but no O/D.
So, any thoughts on what I should check next? Or should I just pack it up and send it away for a rebuild?
TR3driver
Great Pumpkin - R.I.P
I've never worked on a D-type, but I think you can access the pump non-return valve, and pressure relief valve without removing the unit from the car, through plugs on the bottom. Might be worth cleaning them, although any significant dirt probably means it's time for a rebuild anyway.
J
JKB1957
Problem solved. I went back and checked all of the electrical connections, everything was perfect. Then I pulled the cover off the actuating lever. No movement. Played with the solenoid push rod and got it to work. On the road, nothing. Pull the cover again, play with the actuating level and very small movement. Diagnosis, bad solenoid. Next problem replacing the solenoid on a "D Type" overdrive. I've done it once, less then 2K miles ago on this car. I've also had kidney stones. It's a toss up as to which is more painful. Later.
TR3driver
Just a thought, I found that the replacement solenoids (my A-type takes the same as your D-type) don't last nearly as long as the originals do. I'm not sure yet how much it will help, but I added a diode across the pull-in coil contacts in the end of the solenoid that should, at least in theory, make the contacts last longer. The same approach worked a treat on the operating relay. I had 3 different replacements (including an expensive reproduction) fail within a year; but now with the diode the same "cheap Chinese" relay has lasted almost 20 years and still going strong.
Don Elliott
The solenoid in my 1958 TR3A failed when I was at VTR in 2000 in Portland Oregon (7300 miles round trip) so I ordered a new one from Moss in California. It worked about 5000 miles and then failed. I had since repaired my original (cleaned the contacts and soldered a couple of tiny wires) so I put that one back in. I took the "new" repro from Moss apart and found a lump of white RTV rubber wedged in between the internal contacts. They had put too much in when they built it and the RTV piece (the side of a large green pea) was the cause. I pulled it out and this repro solenoid is still my spare - just in case.
J
JKB1957
That's a good idea. Thank you. I also found a site that suggested using a long bolt underneath the solenoid to make it easier to replace.
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
