TR2/3/3A A type overdrive installation
Gordon_Dedrick
I am almost ready to install a late TR4 (with the thicker bellhousing) A-type o/d tranny in my 59 TR3A. Planning on getting the extra pieces from Quantum- switch, right angle speedo drive, relay, harnesses, etc. Other than longer bolts for the bellhousing what unknowns am I looking at? Will I need to adjust driveshaft length or is this unit a "bolt in'? Looking forward to having the Laycock unit but don't want any surprises.
Thanks
Gordon
TR4nut
You shouldn't need the right angle speedo drive, the cable can come straight out and is covered by the handbrake boot. I think in going from a non-syncro box to a full syncro box the rear mount holes will be slightly further to the back of the car, so elongating the holes on the mount crossmember will fix it. Drive shaft will be fine - no other modifications needed I think. Teri Ann Wakeman wrote up her experiences here:
https://www.tr3a.info/gearbox_swap.htm
Geo Hahn
Pretty obvious but just in case -- if your '59 is pre-TS50000 then the bulge in the bell housing won't accommodate the original starter. The are a couple of ways around this, some uglier than others.
TR4nut
I was thinking it was the other way around? The earlier gearboxes were shallower and couldn't handle the later style starter? But along those lines with a later gearbox potentially you could have a little interference with the gearbox tunnel cover - I seem to recall Randall mentioning that once but I may not have that correct - but I also recall it wasn't that difficult to massage out any interference.
Randy,
You beat me to it. I was going to say its the other way around with the starters. You can get by without the angle drive but I recommend using one, you can probably get by with original cable that way and let it lay on top of trans.
marv
TR3driver
Great Pumpkin - R.I.P
Nope, you got it just right.
Other minor points that I didn't see mentioned:
May need longer studs (the 3 studs at the top of the engine block).
May need to shorten clutch pushrod.
If you do have a pre-TS50000 car, you might want to consider moving the dipstick to the new gearbox.
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
