TR2/3/3A A type overdrive
Graham H
My 3A has an A-type overdrive which I believe came out of a TR6 so is the later model with the smaller accumulator piston.
About six months ago I fitted a new oil pump and accumulator cylinder to try and fix a low or no oil pressure problem and after reassembly, the oil pressure came up straight away with instant engagement on a road test.
Last week I noticed there was no overdrive after running for about one mile but after 3 or 4 minuted running the OD came back and seemed ok. After stopping at the shops for about 20 minutes I tried the OD again and it would not work until I had driven for 3 or 4 minutes.
I have now taken the transmission cover off checked the oil level and all the electrics and lever adjustments and fitted my pressure gauge. No oil pressure until run in gear for 3 or 4 minutes then pressure came up to normal and OD engaged with a pressure drop off and recovery as it's supposed to. After shut down the pressure drops back to about 300lbs then slowly drops to about 100lbs and stays there for about two minutes. If I start it up again the pressure comes up straight away and it's all good, if I let it sit for about 10 minutes I have to wait for the same 3 or 4 minutes for the pressure to come back.
Does anyone have any ideas what could be the problem?
Graham
Graham H
Graham H
Thanks, Randall it may be as simple as a piece of fluff under the ball letting all the oil drain out of the accumulator circuit the only way to find out is drain the oil and take it apart.
Graham
Graham H
Graham H
Hi Phil,
The accumulator cylinder has an O ring that seals it in the casting when I first took it apart the O ring had a large bite out of it which was replaced with a new one. After the initial running of the OD, it lost pressure and I took it apart again and found the O ring was damaged as before so I may be looking at the same problem again.
This unit has been an ongoing drama it works for a while then fails again, it could be a lemon and I need to look at a replacement but I will persevere for now and see if I can't fix it.
Graham
philstr6
graham
I m talking the small pistion thats inside the accumalator that has come out
pm me your number and I will call you
Phil
Graham H
Graham H
Phil
Sorry, I haven't got back to you I have been busy pulling the box out and after dismantling can't find anything wrong with it. Will report back after it's back together, about a week it's been a bit hot the last few days 35c.
Graham
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
