More on A Type The Overdrive
KVH
On my 4A, I'm a slow learner. I've rebuilt the OD again, this time to better seat the front annulus bearing. The input and output shafts now seem to spin more freely.
As Randall and a few of you may know, I'm trying to "bench" test the OD with a 1/2" drill. It sort of works, but not good enough, and my hose union between the drill and input shaft still wants to spin, partly because it appears the hose isn't tight enough--or because the resistance is still for some reason too much.
I can't believe I still a bearing not seated correctly. I wasn't very bold with the press, but I also didn't want to damage the casing and I went gradually until it stopped moving and until the force seemed heavy.
I'm inclined as shown in the various articles to buy a cheap motor and a couple of pulleys, keeping RPMs below 800.
As I wade through all this, I guess I'd better ask some more questions. First, the input shaft turns noticeably more easy in first and second gear than in fourth gear. Third gear is also easier than fourth. The "drill test" seems to work best in first gear.
Does all that seem right? Less resistance in first and second?
For some reason I'd thought that the resistance at the input shaft would be greater in first and second gear.
Second, no matter how hard I try, there's no way I'll get 4.2 pints of gear oil in the transmission. Is the shop manual wrong about the capacity. I'm getting about 3.5 pints.
I also wonder if my brand new thick and chilly GL4 gear oil is part of why I'm feeling a little more resistance than expected.
I'll do a third tear down if I need to!
Thanks all.
TR4nut
Absolutely less resistance makes sense in 1st,2nd and 3rd- thats your gear ratios at work.
If you can rig up a socket on your your drill, I run the overdrive from the output flange - no slip that way.
Moseso
+1, on above. The resistances are entirely correct.
Cold, thick oil WILL make the gear box stiffer.
The last time I assembled/bench tested mine, I almost smoked my Milwaukee Magnum 1/2" drill. I did start to smell it. So, I stopped. But, the next day, before I stripped it down again, I tried one more time -- running it for a while in 1st gear to get things moving and then up through the gears. It worked.
I won't be all "surprised," however, when that 30-year-old drill needs to rewound.
K Is there more than one type of 16P brake caliper? Triumph 14
S One more for my E-type URS-Unit - on Anti-Squat... Jaguar 1
David McLaughlin Movies! - Jaguar E-Type, Lotus Elan, Mini Cooper and many more! Jaguar 4
J New Jaguar X-type lease rates..becoming more competitive! Jaguar 2
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
