More Shroud to Scuttle install
RestoreThemAll
  1. At the front bottom of the front shroud, underthe grill, the sheet metal curls under to form a nice finish edge. On my car one side is curled tight and the other about ¼” open. Which is correct?
  2. More important, the gap between the scuttle and the shroud is about ¼” at the demister slots. I’ve taken several measurements and observations from different angles with the shroud in place, and all mounting holes lined up. Using a level, the scuttle is flat enough. The shroud is bowed up slightly. Other than that all looks OK to my eye. Do the demisters pull the gap closed at all once installed? Does anything else pull it closed? Is that ¼” gap OK?
  3. If the gap is OK, what is the best material to fill the gap around the demisters? Foam strips? I plan to use 3M seam sealer between the scuttle and the shroud, where it fits tighter.
R
RestoreThemAll
Dougie,
From your response can I assume that a 1/4" gap is normal?
Lin
Dale,
I am kind of late to the game, but if you aren't already past this stage, the photos below illustrate a tip that someone (probably from this forum) shared with me. As you can see I used dum-dum as Randy suggested. However, before final assembly if you put wax paper between the shroud and the tub and then press pretty hard you can see where the dum dum is compressing and where it isn't. This gives you a clue about where you need a thicker application of dum dum or not.
Lin
R
RestoreThemAll
Thanks Lin. I'm not past that stage yet. Thanks for the tip. Very helpful.
Da
M More Shroud Questions Austin Healey 7
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
