J-Type overdrive for sale on CL
John_Mc
J-Type Overdrive on CL
Is this from a Triumph or a Volvo, and, if the latter, is it easy to adapt to the TR6? I'm guessing by the serial # that it IS from a Volvo. And how does it compare to the A-Type (from any personal experience)?
Also found today on CL, a supercharger.
TR3driver
Great Pumpkin - R.I.P
Has the wrong speedo fitting for a TR, so Volvo seems likely to me. Check out the Quantum Mechanics web site, he sells a conversion kit. Don't forget, you'll have to disassemble the unit to change the speedo gear (which of course I think is a Good Idea anyway).
I have an A-type in the TR3, J-type in both Stags. IMO the J-type is stronger, more rugged and easier to service. If all you want is a 5th gear for cruising, it's an excellent choice.
But the A-type is more sporty, IMO. Engagement is instantaneous and 2nd OD is an almost perfect split between 2nd direct & 3rd direct. I'm kind of sorry I didn't hunt around for an A-type to go in the Stag.
TRopic6
Looks like one for a Spitfire 1500; the upper holes are for the topcover/shifter. I bought a 1500 OD trans for some internal parts for a TR6 J-type I have. Never got around to the rebuild but will check the #s when I can get to the OD.
Jeff
74.5 & 75 TR6
RomanH
I have to agree with Jeff. I have a Volvo J type and the overdrive ratio is 27%. If the serial number stamped in the case is to be believed that unit is 25% which is what Triumph specified for their J types.
TRopic6
I just checked mine and "25 115867" is a J-type for a Spitfire 1500. A lot of J-type internals are common but you'd have to compare the part numbers. As others have said, the OD unit itself is sort of the tip of the iceberg when converting a non-OD box to OD.
Jeff
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
