TR6 Overdrive Mount / J-type on A-type frame
71tr
One of my biggest projects with the TR6 was to add a J-type overdrive unit to my standard transmission. As daunting as that seemed, but really was not, my challenge now is how to mount this thing to my old style A-type frame (1971). I searched the web high and low and there are relatively few options. I initially built a home brew mount similar to the first image below but wasn't convinced it was robust. The big three suppliers in the US don't offer any option so I went oversees ultimately to Moss Europe. They do offer a professionally designed bracket that I liked so I pulled the trigger. All-in with purchase price plus shipping to the US was about $180. Quantumechanics sells the same or similar unit here in the US but at about $200. Surprisingly, I initially made a request to Moss US if they could get the European unit and sell to me locally. They said sure but suggested the special order price and shipping would total $280 so I passed and purchased the unit directly. Very pleased with the outcome, see second image for Moss Europe unit.
That one is pretty sharp but you could have used a mount from a 75 or 76 TR6, drilled a couple holes and mounted it in your 71for a lot less. I've done it a couple of times.
Marv
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
