TR4/4A TR4 A Type Overdrive Part mixup
jimstr4
After finding that mainshaft 3rd lost a tooth into layshaft 2nd and mainshaft 2nd, I decided to have my friend the mechanic overhaul the gearbox and overdrive.
I decided to replace all bearings with the best I could find.
In other words no no-name ones. Bought them from Rimmers, TRF and a local bearing supplier in New Zealand.
The costs are building up.
Upon opening up the the overdrive we found that the rear thrust washer had shattered due to no centre thrust washer (part no. 505548).
My friend said that it would be best to replace the accumulator piston rings (part no.505555) which I ordered from Rimmers.
The two rings were 1 1/4" diameter, my piston requires 4x 1 5/8" rings.
Both TRF and Rimmers list part no. 505555 for an A Type TR4 overdive.
The rings look like they will fit a later Triumph 2.5 overdrive accumulator.
I'm confused.
I'm fairly sure that the box/overdrive is the original factory one.
How many rings should my accumulator piston have?
Do A type overdrives have two or 4 piston rings?
Thanks
Jim and the 1962 TR4
TR4nut
Jim-
I agree with Phil, the smaller rings are used if you have a smaller accumulator as was put in the IRS models (there is also an aluminum housing with the smaller piston). Part 505555 is for the smaller piston setup. It sounds like you have a larger piston accumulator, found in the earlier cars. TR4A was a transition car, so its possible you had a larger accumulator until they switched to the smaller piston. In Rimmers I think the part number is 500605. I recommend also trying Overdrive Repair Services in the UK, here is a link to their spares page: https://www.overdrive-repairs.co.uk/buy-spares.php?cat=A Type Spare Parts List
They show part number 500605 at 1.75", but also part number JA975 at 1.5". Hopefully yours is one of those. You can also find potential spares from Healey providers if they are closer to you.
J
jimstr4
Thankyou for yopur help, I was thinking that this question might have been too odd ball to answer.
The serial number is hard to read but I think that it's: 22/1374/017627.
It has a double spring.
At worst we will dress up the rings and put the old one back.
TuffTR250
Jim, when I bought an A-type OD for my TR3 and had to "rebuild" it, the original steel rings on the accumulator piston looked a bit rough. I was advise to dress them as you mentioned. I decided I did not want to take off too much material. So I bought some real fine "lapping paper" and used that. It worked well. I also buffed the inside of the accumulator bore. I bought a cylinder shaped buffing wheel for my electric hand drill from Harbor Freight and used a really fine compound on the buffing wheel. Again I did not want to take off much material. I tried the "air test" as mentioned in the A-Type rebuild articles on the Buckeye Triumph's web site. I was concerned because I could hear the air around the accumulator piston. As I was bench testing the overdrive, I squirted a bunch of 90 weight GL4 gear oil down around the accumulator piston, and suddenly the air noise stopped and the overdrive shifted great. The overdrive has now been working well after installation in the car. I believe it is possible to use the original steel rings on the accumulator, and, especially if there has been some wear, it is best to use 90 weight gear oil.
Bob
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
M TR6 TR4 A Type into a tr6 Triumph 1
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
