J Type Overdrive engage problem
Coyote1
I just finished a TR6 restore that came with all running gear rebuilt but sat for 10+ years with no fluids. I inspected what I could and all appeared to have plenty of assembly lube so I added fluids and started it up. Everything is working good except the overdrive. Sometimes it shifts fine and sometimes it doesn't want to lock up. It tries but doesn't fully engage. Speed/RPM don't seem to matter. Possibly does it more when warmed up. How should I proceed with trouble shooting or fix?
Thanks in advance as I know I'll get some good advice.
Larry
TR3driver
Great Pumpkin - R.I.P
IMO, first step is to get a pressure gauge & adapter, so you can see what is happening. The cure may be as simple as removing and cleaning the "dashpot" and pressure relief valve, but it could be something more serious.
I made my own adapter, but it probably makes more sense to just buy the whole setup from:
https://webspace.webring.com/people/tj/jholekamp/
Coyote1
Coyote1
I read a little on the pressures of the overdrive unit. Wasn't that thorough a piece and all I got out of it was that if the pressures aren't right, you have a problem. Is the pressure adjustable or does it just mean you have a problem?
If that is the case then I already know I have a problem. I would think I just need to pull the valves and filters to see if they are in need of attention.
https://i867.photobucket.com/albums/ab235/lgcotton/Triumph%20TR6/100_3679.jpg[/IMG][/img]
TR3driver
Knowing what the pressure is doing is the first step towards troubleshooting the problem. For example, if you are getting full pressure and it is still slipping, then there is no point in doing anything further, it has to come out to see what is mechanically wrong inside the unit.
Here are some fairly detailed instructions on troubleshooting:
https://www.buckeyetriumphs.org/technical/jod/JOD4/JOD4.htm
Here's another good manual. Although written for Volvos (so some of the pressure values won't be accurate), the OD unit is the same other than the pressure and possibly some minor variations around the dashpot.
https://docs.google.com/open?id=0B2H2NJt34OffMDJjZWU5ZGQtYWJhMi00ODkwLTlmNTMtZDE4YTZjNTRhOTZi
PS, if you want to take the "shotgun" approach, go right ahead. You asked for opinions, mine is that the systematic approach is always better.
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
