TR2/3/3A Overdrive [Type A] Brake Ring Gaskets
RonR
Since there was never a gasket on either side of the brake ring, is there a downside to using Permatex elastomeric spary gasket on the four mating surfaces?
TR3driver
Great Pumpkin - R.I.P
The book specifically mentions not using "jointing compound" between the ring & main casing. Not sure why, but seems like they must've had some reason.
CJD
I used Permatex 518. It's made for joining engine blocks that depend on not increasing clearances once they're joined. Otherwise, I wouldn't expect a 50 year old mating surface to be leak free. But...that's just me. I did see that the manual recommends dry fitting.
titanic
Despite the manual's warning, I have always used a thin coat of sealer, without a problem. I don't understand the reasoning behind the warning-maybe a possibility of clogging a oil passage with sealer.
I am in the process of removing the trans./OD as we speak. One of my goals is to have a leak free OD, a fool's mission , for sure.
Berry
CJD
Good point, Berry. The 518 is supposed to dissolve if it gets in the oil...another reason I chose it.
TR4nut
I think I used Hylomar on the last rebuild, not using any type of sealant seems ill advised to me.
TR3driver
Odd though, that it's only that one joint. If they were worried about clogging passages (a very real possibility with RTV IMO), seems like they'd warn against using it on other joints as well.
KVH
I was meticulous on the rebuild of my OD last year. I really cannot recall everything I did, though I know I tried to follow the "Buckeye" and other materials to the letter. The Buckeye article says: "A small amount of sealer was then spread on the surface of the brake ring that mates with the main casting." My OD does leak, but not from the brake ring. My leak is at the solenoid housing. Just little dribbles but it all adds up.
https://www.buckeyetriumphs.org/technical/AOD/AOD3/AOD3.htm
KVH
Oh, I need to add something to that last post. No way could I have rebuilt that OD without the constant help of those on this Forum. I could probably assemble at least 150 posts and responses, including from a number of you who clearly are the world's data bank for these cars. So I wanted that clear.
Forty-five years ago, over a mere $50, I passed on a cute little MGB and drove 60 miles north of Town to buy a strange car called a TR4. That was surely a major turning point, a fork in the road. I have so many stories, and have learned so much. Like who Kettering was. I also remember two bits of good advice from a guy in a garage. Ninety-nice percent of your troubles are spark or fuel, and no matter how small it is, don't get under it without jack stands.
R
RonR
Thaks to everyone for their replies.
I wonder how the 518 sealant functions as a gasket if it is disolved by oil.
I have read the Buckeye articles a couple of times, as well as the one by the two geneltmen in Oklahoma.
KVH, did you expereience the same issues with the clutch release spring lengths mentioned in the Buckeye article?
The difference in length in the springs I removed is miminal, unlike the pictues of new springs included in the article https://www.buckeyetriumphs.org/technical/AOD/AOD4/AOD4.htm
I need to decide if I should buy new springs or not. I don't have a way to bench test the overdrive so I only want to do this once. I know, it is a british car)
TR3driver
If you only want to do it once, FIND a way to test it on the bench! It's not that hard. Beg, borrow, buy or build a pressure gauge; then cobble up some way to spin the gearbox. I use a 1/2" drill motor & a chunk of radiator hose as that's what I had handy; plus some 2x4 cutoffs to support the gearbox.
R
RonR
I do have a pressure gage.
Randall, how did you connect the drill to the gearbox (or rear flange of the overdrive) using a radiator hose?
I have the gearbox finished. My intention on the overdrive, as it was working when I removed it from the car, was to simply disassemble, clean, and install new gaskets as it leaked more oil than the engine. (engine has been rebuilt) However, I discovered two broken thrust washers in the overdrive and a bent adapter plate (which may have been the cause of most of the oil leaks.)
KVH
KVH, did you expereience the same issues with the clutch release spring lengths mentioned in the Buckeye article? The difference in length in the springs I removed is miminal, unlike the pictues of new springs included in the article https://www.buckeyetriumphs.org/technical/AOD/AOD4/AOD4.htm
Yes, it was very confusing. I marked and measured the springs, and the lengths, due to age, must have changed. They were so close in length that it didn't make sense. I remember even counting the curls. I strongly recommend getting new springs. They are color coded and you won't make a mistake. I'm not recalling all the details, but it's possible that length and strength are factors in the two different springs.
KVH
And by the way, I simply couldn't bench test mine with a drill. I conceded here many times that perhaps my bearings just weren't pressed on perfectly, or some other issue existed, but a one-half inch drill wouldn't spin my overdrive. Therefore, I went to a shop and bought a little pulley and drilled four holes to line up with the holes in the rear flange. Then I went to Harbor Freight and bought a 2 hp cooler motor. And I did it like in the Buckeye (or other) article. Here is a pic, plus a pic of my new springs being examined by my son.
attachment.php
attachment.php
TR3driver
My corded 1/2" drill (an old Milwaukee Hole Shooter) has a section of the chuck that is 1.25" in diameter, same as the outside of the clutch splines on a TR gearbox. I found a section of straight 1-1/4" radiator hose in the junk bin, and used clamps to attach it to the drill motor & input shaft. By positioning the bench vise just so, I was able to lay the drill motor in it, and wrap a tie wrap around the trigger so I could use both hands for other things. Sorry, I didn't think to take a photo.
FWIW, John Esposito sells a thicker adapter plate (which is what I used). It will supposedly fit both 3 and 4 synchro boxes (though I've only tried it on a 4 synchro).
R Overdrive [Type A] brake ring gaskets Austin Healey 1
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
