TR6 76 TR6 J Type Overdrive
Don_Houston
My 76 TR6 has 23k miles and has been in storage for 30 years. One of my final items is getting the overdrive working. It appears that the solenoid is defective. Any tips on installing a new solenoid? They are pretty expensive and wondering what caused it to fail (old age?). Thanks!
TR3driver
Great Pumpkin - R.I.P
Is the coil bad, or just the valve doesn't work? If it's the valve, you might try cleaning it and replacing the O-rings inside.
You'll need a special wrench to properly R&R the solenoid. The largest part of the housing is kind of weak (it just covers the coil) so it's much better to use a wrench on the flats. I cut down a cheap 1" open end wrench to fit.
TR4nut
Don-
Not sure if you've met anyone in the Houston Triumph club (Texas Triumph Register), but we have a couple of club members who can help if needed I think. One in particular rebuilds most of the gearbox/overdrives in the club.
We meet up informally every Saturday for breakfast, its a good time to drop by if you can. Closest to you in terms of breakfast spots is Seabrook Classic Cafe once in a while, or if you are free Sept 7 we'll be at the Busy Bee Cafe in Pearland. Drop by if you can.
Randy
Don_Houston
Thanks for the help and sorry I didn't get back sooner. I did put a new solenoid on and the OD works. Nice to have a fifth gear out on the highway. What is the recommended operating procedure? I don't see much use for the OD in 3rd gear (let me know otherwise). In 4th gear should I be above and/or below some rpm before engaging? Should I be accelerating or does it matter? Is there a recommended rpm range to disengage? I just want to make sure I don't mess up the OD. Many Thanks!
TR3driver
The OD is pretty rugged, you're not likely to damage it no matter what you do. But if you want to baby it, then shift like it was just a 5th gear: depress the clutch, flip the switch, wait the beat or two it takes to shift, then release the clutch.
With a J-type I agree, OD in 3rd gear is pretty much useless.
MDCanaday
You did not mention the flush out and cleaning of the filters.......A good OD deserves
respect and love and a good 70wt gear oil(synthetic) to make it to the next 50 years.
MD(mad dog)
TR3driver
True, they do require periodic maintenance, just like everything else. My personal favorite for oil is Redline MT-90, which is a full synthetic GL4 that has been specifically formulated for use in manual transmissions.
Don_Houston
Thanks for the great tips. Will do the maintenance. I was not using the clutch when I engaged the OD. Hope to get the car running reliably (see other thread on idle). Thanks!
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 Coolant Type? Triumph 5
M TR6 TR4 A Type into a tr6 Triumph 1
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
T TR6 TR6 J-type OD stuck engaged Triumph 9
T TR6 J-type OD to replace A-type in a TR6 Triumph 7
R_Lyle TR6 TR6 J-Type overdive hard engaging Triumph 9
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
I TR6 What type of oil for TR6 rear shocks? Triumph 2
Steve1970 TR6 TR6, how to free the j-type OD switch from cowl? Triumph 4
kodanja TR6 TR6 Ford type 9 conversion Triumph 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
