TR2/3/3A Installing small body stone guard
Tinkerman
Had the rear wings on and feeling pretty good about it when I noticed that I had left the small body stone guards off, sigh. Had to take the wings off for another reason so I'm ready to install the stone guards. Any hints, tips or other comments about the installation of those stone guards?
Your thoughts or comments about the installation of the guards greatly appreciated!
Thanks, Tinkerman
Geo Hahn
Not sure the wings have to be removed to install them - possibly just loosened enough they can be slipped into place.
You may have to tweak them a bit for a good fit. Depends in part where they came from. One well-known supplier sent me a set of the small ones that were so far removed from what would fit that I returned them and ordered from another source.
TR3driver
Great Pumpkin - R.I.P
The ones I got also needed a lot of modification to fit. Fortunately they were oversize, and very soft, so it was easy to cut them down. Unfortunately, the body shop I paid to do the work did a lousy job of it. But no one seems to notice except me.
Tinkerman
Tinkerman
Yep Randall, we do tend to be our toughest critics. But I guess that's why we're in this hobby.
Thanks, Dick
charleyf
Dick,
If you kept the old ones to use as a pattern it really helps to"modify" the new ones. One my TR3 I spent the better part of a day working on those front/ small ones to get them to fit like the old ones. Like Randall the new ones had more material and needed to be cut down ( in my opinion). It has been a few years now and I am again working on a TR3 so will get to see how the newer ones are fitting. In my opinion the upper edge was made with way to much distance between the body and the guard.
Charley
Geo Hahn
...the new ones had more material and needed to be cut down... In my opinion the upper edge was made with way to much distance between the body and the guard.
Agree - here is the new as supplied (left) and the old as removed (right):
Note - the old one pictured was not original, it came from Vicky Brit some years back.
Tinkerman
Tinkerman
Thanks Geo your pictures helped and made quite a bit of sense to me about what I have to do.
I gather that not all of the hew replacement stone guards came from the same mfg?
They are not horribly expensive I may need to order another set for comparison purposes.
Thanks, Dick
Tinkerman
Tinkerman
I notice that on mine there are 2 small (1/8") holes drilled into the bottom and side sections. I' guessing some hold down screws? Any thoughts (size, lengths) on these?
Your thoughts and comments greatly appreciated!!!!!!!!!!!!!!!!!
Dick
charleyf
Dick,
They are for screws. Size? Small, short sheet metal.
Charley
TR3driver
According to the SPC, there are two YA0124 and two YA0183
YA0124 is #4 "self tapping", 1/2" long, "flat countersunk" head.
YA0183 is #4 "self tapping", 3/8" long, round head
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
