    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
1979 B Owner's Manual
AngliaGT
I've got a '79 manual,in real nice shape -
anybody have a '67 GT manual that they'd like to
trade?
- Doug
Greg:
Post your request on the "Spridget Forum" here at BCF (instead of here)....you'll get more responses. :yesnod:
I would like to buy a manual for a 77 MGB if available. How much is the 79?
All manuals are available new in reprint through Moss, etc.
Most OE owners manuals that I see sell, go for the same or more than the new reprints.
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
N MGB 1979 MGB exhaust replacement. MG 1
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
A MGB 1979 MGB Flasher Big Headache MG 3
T MGB 1979 MGB with Weber carb MG 7
R MGB Testing temp sending unit 1979 MGB MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
B 1979 MG Midget Headrest Available! Spridgets 3
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
I 1979 wont go into reverse MG 10
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
