Carb Choke Cable
ddeholl
Carb choke cable issue-help! Recently started up my BJ8 after several months in idle. I found that the cable to the rear carb was sticking, and was able to release the primary cable from the dash at the "body" (Moss part 125) and lube the carb choke cables. Good news, each carb cable works fine. Bad news, I cannot get the primary cable back into the little block (Moss 128) . The set screw damaged the 1/16 cable so that a few of the fibers in the cable are "off", and cannot get into the block. If you feel the cable, it is what in the Navy we called "Fish hooks" in much bigger cables. So I just got a new Primary Carb choke cable from Moss. That was NOT without looking at what it would require to put it in. Looks like very difficult access.
So here is my dilemma, I can keep trying to get the old cable to work (suggestions?), or I can try and pull the old cable out of the old sheath, and push in the new cable ( sizes appear to be the same). What I can't see is what is the locking mechanism for the individual carb choke cables to that little block (again Moss 128) . Seems as if taking out the old cable from the old sheath and trying to put in the new cable from the new sheath might be risky.
red57
One trick we used to do with motorcycle throttle cables is to get all the individual wires laying snugly together in their natural undisturbed twist and "tin" the last inch or so of the cable with solder. Wiping off the excess before it cools. If you can get solder to stick (need to de-grease it well), it will prevent individual wires from un-raveling as you push it thru the outer cable housing and thru the trunnion.
ddeholl
Thanks, I will try that. I am afraid I erred in making the detachment at the Primary (dash to "block").
bob hughes
That is strange, I seem to have a single wire as my primary cable on the BJ7, I replaced the Primary system back in 2013 but I can not remember if it was just the knob or the whole thing. The bit of cable showing looks to be reasonably fresh so I guess that it was the whole system.
:cheers:
Bob
Dr. Smoke
Member
My problem as well. Now that it is getting colder, I need my choke. But, pulling it out from the dash to engage the choke, it will not pull. Is there any way to lubricate this without taking the choke assembly apart?
Smoke
Not necessarily a cure, but if you press the accelerator pedal to the floor before pulling on the choke at least you won't be fighting the throttle return springs (since SUs don't have an accelerator pump you don't risk flooding). My preferred lubricant for this type of applications, like speedo cables, is silicone lubricant; it tends to attract less gunk than petroleum products. I'm not sure, but I don't think the cable sheaths are lined, squirting some into the end and along the cable might help.
LAW75
The choke unit, new, cost about $25-30. Skip the frustration and buy then install. Good idea?
R TR4/4A how does choke cable attach at Carb 65 tr4a? Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
B Front carb choke linkage pin Triumph 5
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
B Carb/Choke Question Spridgets 10
S HS2 SU dual carb throttle/choke linkage Spridgets 10
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
bluemiata90 SU CARB---CHOKE PROBLEM Restoration & Tools 2
jlaird Interim Carb and choke report Spridgets 8
V Choke cables for tri-carb Austin Healey 5
O Wedge TR8 carb. choke parts Triumph 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
