The 100 engine
simon1966
My 100 engine is stock. I plan to pull it so that the body/chassis can get the attention that they deserve. What is the current thinking on these engines. In particular I am concerned about unleaded fuel and am curious if I am better off going for one of the replacement unleaded heads, or working with the original head. My heart says stay original, my head says maybe it is the time to upgrade the engine. Input into this decision would be appreciated.
Healey 100
If you use the original pistons, the compression ratio on these engines is low enough so they run fine on regular gas. My 100 engine had been modified back in the day with oversized high compression flattop pistons and definitely needed premium gas to keep it from pinging and running on. On the last rebuild, I sleeved it back to the original bores and pistons. It definitely lost power when I went back to original but no longer pings and I use unleaded regular gas. It is still a very lively engine and I worry just a bit less about breaking a crank or blowing head gaskets -- common problems with the 100 engine. I personally think the need for "unleaded" head modification (carbide seats) is overblown. As long as the octane is high enough to prevent pinging, the unleaded gas should not hurt your engine. If there is an issue with unleaded, it may be with severe operations with sustained high speeds, not likely to be an issue with most street Healeys. p. s. check your head carefully when you rebuild. Cracks are common that leak water and erode the valve seats whether they have carbide inserts or not. I did buy a Welsh head because of cracks in mine, but I have not installed it yet -- the cracked head works OK but if definitely limits the life of my valve seats.
Incidentally, the 100, and most 100/6 engines, were manufactured before they started putting lead into the gasoline, sometime in the late-late 1950s, according to my (also late...) father.
If I was doing a valve job and needed seat work anyway, I'd go with either induction hardened or hardened inserts. I don't know if this was a result of a singular poor quality installation, I did have one (1) seat become dislodged on an MGB engine__amazingly with no collateral damage.
If you're having to make regular adjustments to the valve clearance (as a result of valve seat recession) then it should be addressed, otherwise, I agree with Healey 100's statement above.
DerekJ
In general, running an unleaded engine without valve work isn't a problem for normal useage. However if you are stripping the engine and have the head off then it makes sense to have the exhaust valve work done at the same time. 100 heads are prone to cracking so the next step is an aluminium head. The ones made by Denis Welch are FIA approved but they are pretty expensive.
5
57_BN4
Your standard head will work fine with unleaded fuel unless you plan on towing heavy loads for long distances. Unfortunately it will almost certainly be cracked to some degree and this will most likely determine how you proceed. There was a recent thread on the same topic. Andy.
simon1966
simon1966
THanks for the input. Very clearly I will need to get the head inspected by an expert to gauge its condition. Since it is 59 years old I guess it should be expected to show some wrinkles!!
pan
I had hardened valve seats fitted to an A90 Atlantic cylinder head about 18 years ago. Australia went lead free in the mid 80s.
I have had no trouble with the head since.
Can you still get 'soft' valve seats?
R For Sale 100 engine block w/head Austin Healey Classifieds 3
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Dandare 100/6 Engine Backplate Austin Healey 4
W Looking for engine rebuilding 100-6 Austin Healey 12
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
L First 100 Engine Serial Number Plate Austin Healey 13
T Austin Healey 100 engine color Austin Healey 10
D Engine 100/4 Austin Healey 10
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
A 1954 100/4 Engine specs Austin Healey 2
B 100-6 galley head engine - Do I feel lucky? Austin Healey 23
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
A 100 engine main bearing cap nut question Austin Healey 0
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
H 100/4 engine block Austin Healey 0
T 100 Engine Lifting Device Austin Healey 25
OZ_BN1 100/4 Engine Austin Healey 12
W Replacement frame engine mounts for a 100-6 Austin Healey 4
J 100-4 engine hardware Austin Healey 17
Z 100 engine/gearbox adaptor plate Austin Healey 3
andrea AH 100/6 Longbrige 1957 engine comp,Wiring Harness Austin Healey 9
H 100 Engine Timing Chain Tensioner Austin Healey 3
G Early 100/6 engine, automatic transmission Austin Healey 2
H Need Healey 100 engine parts Austin Healey 4
HEALEYJAG 100-M engine on EBAY Austin Healey 2
T 1955 100-4 Engine Paint Austin Healey 8
AngliaGT TR6 TR6 Engine - $100 Triumph 5
mbrooks 100 oil leak from front of engine Austin Healey 3
mjobrien AH 100 - Chassis and Engine Numbers Austin Healey 8
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
