AH 100/6 Longbrige 1957 engine comp,Wiring Harness
andrea
I need help for rewiring my Longbridge car
Wiring harness was probably burned and car
arrived to me completely rewired in bad manner
So I have not possibility to make photos of the detail of engine comp. wiring harness route.
Don't worry I have collect thousand photos and I have make one sketch
https://picasaweb.google.it/lh/photo/ylmdhidW1C4B8EJ91jNL9w?feat=directlink
https://picasaweb.google.it/lh/photo/L0ckQEx1TV7AXDw4btva5A?feat=directlink
Now I have TWO questions:
Route of capillary temp pipe on LHD car
And where go the extreme RIGHT harness that
route in direction of cool air duct
Please advise me if I made mistakes on my scketch
Tanks in advance
Andrea
Johnny
Andrea, I will try and help. The temp tube goes to the front of the engine block and then is routed up and along the heater pipe where it is held in place by clips that attach to the carb choke cable brackets. Where the tube goes into the firewall it is coiled up about 3 times and is held together by a rubber strap. I have found it useful to first connect the tube to the temp gauge, coil the tube then connect to the block.
The wiring harness on the right side, looking from the front of the car, goes up and over the steering box and down along the fender well (there should be clips welded to the fender to secure the harness) then along the bottom of the brake relay box and on to the front of the car.
andrea
andrea
Tanks Johnny for your help very useful
I understand perfectly the capillary temp, tube route-and also the route of the harness to the front
https://picasaweb.google.it/lh/photo/HoeZftRNocyWNaqSYb1JaQ?feat=directlink
but I look on this photo extreme right corner of firewall(is one Abingdon car)
https://picasaweb.google.it/lh/photo/WZx57dEW7aWJdp40p9A2_A?feat=directlink
some wiring and also one pipe (oil pressure to gauge??)
and also one wire penetrating on the pedal box
This side of engine comp. is not loved by photographs and usually covered by the wings
the only help that I have is this Abingdon (probably Bj8
)shot
https://picasaweb.google.it/lh/photo/fATnPskwpNThrdRRwgO05g?feat=directlink
Have a nice day
Abdrea
I would think a Longbridge car would be the same as my (very) early Abingdon car; along the right side of the bonnet opening, to terminate in the front of the radiator (as opposed to the cylinder head).
The capilary tube is exiting just above, and to the left of the voltage regulator.
andrea
andrea
Hi Randy
This is the solution for RHD cars but I suppose that
also British have find one better solution for LHD cars where the Oil pres and Water temp GAUGE are at the opposite corner.......consider that about 90% of
100/6 production was exported to US
My car is # 43214 but have a 26 RU 77... engine
-late six ports head -so I have bayed 3 WEBER 45DCOE
What solution have you adopted for accelerator throttle command on yours? -
I don't see any Overdrive Relays on your car
Tanks for help
Andrea
vette
Andrea, I believe the small two wire section that is penetrateing the toe box on the left side is for the High/low beam dimmer switch. I remember taking it out of mine when I took the car apart.
andrea
andrea
TANKS again for helps- I am at 96% certain -about the wires route in the engine compartment- the 4% is the right quantity that all must have
beginning a new work
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 8
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 2
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
H 100-6 Interior Installation Austin Healey 4
