100 timing chain worn?
Lambdaman
Hi all
I have been trying to track down an elusive noise in my engine compartment . It appears to be coming from the from the frontal area near the radiator. It is a metallic tinny
rattling vibrating noise, it appears at low revs at idle and disappears when revved. I have removed the fan belt and it persists so,it is not generator or water pump. I have held the exhaust down pipe when it is present and have not been able to damp it either. I able beginning to suspect that the timing chain may be worn or stretched and may be slapping on the inside of the timing cover.
any thoughts ?
Regards
David
Healey 100
Mine made a noise like that years ago. It was a fairly slack timing chain. There is also a neoprene tensioner around the cam sprocket that takes slack out of the chain. Fortunately, it's not too hard to replace both chain and tensioner.
Patrick67BJ8
Did I read/see and ad for an upgrade timing chain tensioner someplace and maybe from one of the UK suppliers? Anythings better than the original setup.
Genos2
Also check that crankshaft pulley retaining nut has not loosened up & allowed pulley to walk on woodruff key, used to see that a lot.
pan
I'd agree with Healey 100. The 100 engine has a ring on the camshaft sprocket which tensions the timing chain. Ignoring the noise can have disastrous consequences. It is not a difficult job to replace the tensioner but it is a lengthy one.
L
Lambdaman
Thanks every one for responses, have gone to order a new chain and they are currently unavailable form AH Spares and Ahead 4 Healeys, anyone know another source?
regards
David
vette
Don't know what part of the world Newcastle is in but try Healey Surgeons, Maryland just outside of DC.
pan
David,
Don't forget to replace the 'rubber' tensioner on the camshaft sprocket as well as the timing chain.
H 100 Engine Timing Chain Tensioner Austin Healey 3
mjobrien Timing Chain Tension for 100/4 Austin Healey 1
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
M 100-4 Timing Pointer Austin Healey 5
J 100/4 timing mark relocation Austin Healey 2
mbrooks 100 timing cover wanted Austin Healey 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
