MGB Need some brake line clips?
Rut
I'm looking for 3 brake line clips for my B, # 37, 39, & 40, NLA from Moss.
Thanks, Rut
update, found a full set from British Masters!
Thanks all, Rut
Rut
Rut
Drew,
Thanks! I saved that site for future needs, but they don't carry the ones I'm looking for.
Rut
Rut
Rut
Bump...
PAUL161
I know of no one that sells those clips new. B&G has all the clips but those. Abingdon spares doesn't have them either. PJ
Rut
Rut
Paul,
I've exhausted all the sources I can find for new ones so I'm looking for used. I'm hoping someone with have a parts car with some left on it.
Thanks, Rut
PAUL161
I understand Rut. There was a fellow a while back that parted out a TD, I think his name was Harvey-??, not sure. I did buy a few parts from it. He favors another forum. If I can find him, I'll let you know. PJ
PAUL161
Rut, Contact Ken Harvey at kharvey5565@att.net
He parted out a TD and I think he still has the chassis plus a few more bits. PJ
Rut
Rut
Paul,
thanks for the info! I found a full set and I'm good to go.
Thanks, Rut
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
S TR6 Need wisdom on tr6 brake calipers Triumph 6
N Need brake bleeding advice Spridgets 6
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
N Need Brake Bleeding Help Spridgets 25
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
T 77 with twon SU's- need to remove brake servo MG 2
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
J rear brake rubbing, need suggestions Triumph 12
HAN8L1965 Need a Brake Light Switch Spridgets 3
K Need Email for CK Technologies Re: Blinking Brake Triumph 9
M Need brake mechanic in Austin, TX Spridgets 22
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Marvin Gruber MGA Need MGA Front and Rear Brake Drums MG 13
c5racer Need E Brake Parts Spridgets 1
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
M Need Some Advice on a BE Emergency Brake Spridgets 13
jmwuva05 I need a four way brake union bad!!! Spridgets 4
M Brake job - need some advice Austin Healey 7
1 Brake calipers--need to repair? MG 27
F porterfield brake shoes [need cores] Austin Healey 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
