Need Brake Bleeding Help
N233TX
'75 Midget 1500 Fluid mysteriously lost from system (none on floor or apparent mess on wheels.) Proceeded to bleed as per manual. Cannot get fluid to either flow into bleeder jar or suck back out when pumping pedal. Tried my EZBleed and could neither push fluid in or suck any out. Can't get a helper right now to pump the brakes. Don't see any broken lines.
Right now the master is topped off and the bleeder tube is submerged in the bleeder jar and nothing moves when brake pedal is repeatedly depressed and released. I've successfully bled the brakes on this car before...no problem.
I'm thinking the master is shot somehow but it has less than 1,000 miles (and 10 years) on it. Brakes were fine when last driven 2 weeks ago.
Could someone who really understands the system offer some trouble-shooting advice here?
TIA Jim
No fluid on the carpet/floor mat?
Deleted member 8987
FIRST thing I would do is ensure there is no air lock in the master.
Pop the line on the mater outlet, hold you finger over it while an assistant slowly presses the pedal, allowing any air to escape by releasing finger, place finger firmly on opening while pedal is released. Do it several times. If you get flow, re-attach line, crack it and press pedal, tighten, do it again until air stops popping out around the line.
Same as bench bleeding a master, which you have to do new.
Dual master, I'd do the port closest to the pedal first.
1975.....do you have a booster?
Pull the master. Look down inside, see of you have a booster full of brake fluid.
If so, remove it, drain, it, flush it with some spray brakekleen, re-install, then NEW master.
At least that's what I have done for many years...successfully.
Dave
N
N233TX
Floor is dry. Will proceed with suggested fix. Never heard of an air lock. Would that create the symptoms noted? e.g. inability to either extract or inject fluid?
Deleted member 8987
Running fully out of fluid as you stated initially will do it.
"Prime the Pump" is another term.
When you buy a new domestic master cylinder, there are instructions for bench bleeding. You MUST do that or you'll by stroking that pedal for days with no results.
Not saying that's it....but one thing you'll know immediately is whether the master works or not, and proceed from there.
JPSmit
May i also suggest you pull the switch assembly and clean it. ( that brass piece that dircts flow to the brake lines.) i was stunned how much crud there was in it. IIRC i also put a nipple on it and bled the brake to there before going on to the hubs.
N
N233TX
OK, weather delays and back to the problem... Took poster advice to inspect and rebuild the switch assembly. It was very clean but cleaned as per and installed new o-rings. Figured it would be a good idea to rebuild the master while I was at it. This rather challenging procedure revealed a clean bore and I carefully installed the myriad pieces, constructing fixtures to do so, double-checked the assembly and successfully bench-bled the master using clear tubing to remove all air bubbles. Cussed my way through master re-install, spilling the requisite amount of fluid on the rag under the brake pedal.
Current situation: starting at right rear bleeder valve, no-go on traditional bleeding or EZ Bleed vacuum or pressure...no fluid at all. Ditto left rear. Can't get fluid to push up the line (my favored way to bleed). Pumping brake pedal moves some fluid out of both front bleeder valves and fluid level goes down in reservoir.
The rear brakes on the '75 incorporate hard tubing directly to the wheel cylinders so there are no rubber hoses to replace. Should I try disconnecting these and seeing if I can get fluid down the line? I can't imagine a scenario where *both* rear brakes will not bleed properly. Of course I can't figure out how the system originally bled down on its own without leaving a puddle on the shop floor...
I need some troubleshooting ideas before I start tearing things apart. TIA Jim
dklawson
... rebuild the switch assembly. It was very clean but cleaned as per and installed new o-rings.
I cannot comment on why the brakes are not bleeding except that I suspect a problem in the master cylinder. Based on the symptoms I am surprised you did not find fluid in the driver's footwell.
My real reason for posting is your comment that you installed new o-rings. I am not familiar with a switch assembly on the brakes apart from the PDWA. If the o-rings you installed are in contact with brake fluid you may have introduced a new problem. Regular o-rings are Buna-N (Nitrile). Buna is compatible with DOT-5 fluid but not DOT-3 or -4. If you are using DOT-3 or DOT-4 you need to use seals made of EPDM.
SaxMan
Maybe the bleeder valves themselves are clogged? It wouldn't take much to jam them up. If the clog was in the line actual line, I imagine you wouldn't have any rear brakes at all.
bthompson
...which begs the question, do you have rear brakes at all? If the flexible hose over the axle to the rear hard lines is deteriorated and gummed up internally, you could have no rear brakes and never realize it; the fronts do a good job on their own. (Go ahead, ask me how I know)
If the rears work, then the problem, like Sax says, most likely with the bleeder passage or the valves.
N
N233TX
Thanks y'all. O-rings that went into the compensating valve were in the rebuild kit from Moss so they should be brake fluid compatible. Bleeder valves were inspected and found OK. Gonna check that flexible line over the axle. Can't find that part listed in either Moss or Vic. Can somebody give me a part number? What associated parts do I want to get? This hose is almost 40 years old and it sure looks like a likely culprit given that both rear lines seem clogged...
Bigomudders!
Hello having similar problem, but I clamp rear hose and pedal is at the very top great pedal. no leaks in rear system at all. Bleed system thinking I have a air out and pedal will go to floor a couple of pumps and its back at the top and holds DOES NOT SINK. Wait 10 seconds and pedal goes back to the floor. HELP
BobHaskell
Are the rear shoes adjusted to the drums? If you set the parking brake does the pedal still go to the floor after 10 seconds?
Bayless
Not sure I understand "clamp rear hose" and how that relates. But, If you have pedal and it slowly sinks to floor then the fluid is going somewhere. About all that can happen is a leak somewhere in the system and you should find brake fluid. Otherwise it is leaking internally inside the master cylinder, a common problem as they wear. Having to pump the pedal still sounds like rear brakes badly out of adjustment.
BobHaskell
One can close off the rear brakes by clamping the rubber hose that feeds the hard lines on the rear axle. If he has good pedal with the rubber hose pinched close, then the problem ought to be somewhere with the rear brakes. Either too much motion (shoes out of adjustment) or a leak.
JPSmit
what year car do you have? I ask because I wonder if it is still air and specifically related to the splitter for the dual system. I find that when people rebuild these puppies they almost never clean it (including me) and it was disgusting! I would still be inclined to be looking for air in the system.
Bigomudders!
Have you checked the rear wheel cylinders to make sure that neither one is frozen? That the pistons move freely (in and out).
yes new wheel cylinders, new shoes and hardware but OE drums. I'm really starting to believe the drums are way out of spec causing the need to pump pedal.
N Need brake bleeding advice Spridgets 6
S TR6 Need wisdom on tr6 brake calipers Triumph 6
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
Rut MGB Need some brake line clips? MG 9
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
T 77 with twon SU's- need to remove brake servo MG 2
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
J rear brake rubbing, need suggestions Triumph 12
HAN8L1965 Need a Brake Light Switch Spridgets 3
K Need Email for CK Technologies Re: Blinking Brake Triumph 9
M Need brake mechanic in Austin, TX Spridgets 22
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Marvin Gruber MGA Need MGA Front and Rear Brake Drums MG 13
c5racer Need E Brake Parts Spridgets 1
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
M Need Some Advice on a BE Emergency Brake Spridgets 13
jmwuva05 I need a four way brake union bad!!! Spridgets 4
M Brake job - need some advice Austin Healey 7
1 Brake calipers--need to repair? MG 27
F porterfield brake shoes [need cores] Austin Healey 4
tr6web TR6 Need advice removing downpipe nuts Triumph 2
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
