Need brake mechanic in Austin, TX
M
Mike
Looking for a mechanic in the Austin area that can work on my 1958 Bug Eye brake issues.
Morris
I am in Austin and off this week. I can't guarantee that I can fix your brakes but I would love an excuse to come look at your car.
M
Mike
Thanks for the response. What I'm looking for is someone that has a local garage that the car can be left at for repairs. One or two of the brake cylinders is leaking and I'm thinking a complete brake job is in order with parts needed to be suplied by the garage. Let me know if this is up your alley?
Morris
I don't own a shop. But if you want to buy new wheel cylinders, I will come over and help you install them.
https://www.bpnorthwest.com/.sc/ms/dd/Sprite^2FMidget--Braking%20Components/7132/Wheel%20Cylinder%20Rear%20Sprite%20Midget%2C%20Morris
Save you a tonne of money. :wink:
JPSmit
get new hoses at the same time - and possibly pads, do the job once...
G
Morris is more than qualified. Matter o' fact, he really shouod consider doing side work. :wink:
jlaird
You all know I do side work? Computer repair. It is warm inside or cool, and I can sit down. Really I do.
M
Mike
PM Sent to Morris.
Morris
Ugh... been laid real low by a stomach bug. I will give you a call later Mike.
JPSmit
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]not a stomach bugeye?[/QUOTE]
:pukeface:
Billm
Mighty
There is no real upgrade for the Bugeye that really makes much difference for the REAR brakes. You CAN go with the later style ones but there really isn't much improvement.
The fronts do about 80% of your braking and going to the front disks are the best easy thing that you can do.
BillM
Morris
The later style rear wheel cylinders and shoes are a lot cheaper... that's fo sho.
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Brake it up[/QUOTE]
You guys are not helping my belly any with these puns.
:pukeface:
drooartz
mightymidget said:
Is there a upgrade for rear bugeye brakes, or is stock sufficent
When I did the front disc upgrade it was recommended to me that I use the later style backing plates as well, so I did. I find the brakes to be completely sufficient for the car (and this is with a nice Hap-built 1275 in it). The car is so light at ~1500# that more brake just doesn't seem needed for the street.
mightymidget
There are some backing plates on Ebay cheap, Plan on doing a complete rebuild of rear diff. before reinstalling into wifes bugeye. Might as well do the upgrade.
jlaird
Rear end of a BE is so light you will never miss the brakes if gone.
S TR6 Need wisdom on tr6 brake calipers Triumph 6
N Need brake bleeding advice Spridgets 6
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
Rut MGB Need some brake line clips? MG 9
N Need Brake Bleeding Help Spridgets 25
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
T 77 with twon SU's- need to remove brake servo MG 2
CZ_Dave T-Series Need Help, Clutch/Brake MC on 1959 Magnette MG 3
J rear brake rubbing, need suggestions Triumph 12
HAN8L1965 Need a Brake Light Switch Spridgets 3
K Need Email for CK Technologies Re: Blinking Brake Triumph 9
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
Marvin Gruber MGA Need MGA Front and Rear Brake Drums MG 13
c5racer Need E Brake Parts Spridgets 1
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
M Need Some Advice on a BE Emergency Brake Spridgets 13
jmwuva05 I need a four way brake union bad!!! Spridgets 4
M Brake job - need some advice Austin Healey 7
1 Brake calipers--need to repair? MG 27
F porterfield brake shoes [need cores] Austin Healey 4
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
